non-noob altezza question
Old Jun 18, 2002
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
searched and no luck... how do you open the APC altezza tails? like to separate the clear part and the housing?
Old Jun 18, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
I haven't done it personally, but I think you could put them in the oven on low temp for about 10 mins to loosen up the glue, like with the OEM headlights. Then just pull apart.
Old Jun 18, 2002
ChEe12iO's Avatar
in the oven eh? cooking the tails doesn't sound too appetizing. hahaa... i might end up with smoked tails! i'm going to try the heat gun this afternoon and see if that werks... thanks for the recipe
Old Jun 18, 2002
Grey's Avatar
DIY King
Hehe, yeah ovens are a nono. A heat gun is your best bet. I would loosen up the glue with that and slowly peel it apart. Also, you might need an exacto knife to cut the glue as you go. It depends on the consistency of that glue. I don't have APC altezza's, so I don't know what that glue looks like?
Old Jun 18, 2002
MaddonE's Avatar
MaddonE is an unknown quantity at this point
be VERRY careful chee, i tried taking my apc's apart about 2 months ago, i heated them up and the glue would loosen up a little. long story short, i got one side opened up a little but couldnt get the whole thing opened, its TOTALLY different from the headlights. good luck anyway, also, be careful with the knife, any little scratch you might accidentally make will scratch off the black lining (whatever you call it) around the light. anyways good luck man, i just gave up, and sealed the SOB without opening it
Old Jun 19, 2002
ChEe12iO's Avatar
there's got to be a way to separate them without breaking or cracking. does anyone know what the seal mating surfaces look like?
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
