oh man, DIY painting trim problem some 1 please
Old Jun 1, 2002
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
i did the DIY but it looks like it ame out alittle rough and not so smooth??? how can i fix this up?[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Jun 1, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Take some very fine grit sandpaper and sand it underwater. You will have to then repaint it. Try searching next time i know many people have asked this question.
Old Jun 1, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Yeah, resand the vents, and repaint then clearcoat! and u should be fine.
Old Jun 2, 2002
dragoon's Avatar
use a better quality paint. I know the 64 cent paint they have at walmart looks tempting, but try plasti-kote. I didn't even need to sand or clearcoat it, and it came out smooth and still with the original texture.
Old Jun 2, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
dont sand any vinly to hard.. or it will get all rough n messed up
Old Jun 2, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
Quote
[hr]Originally posted by: AzNmiKex215
dont sand any vinly to hard.. or it will get all rough n messed up[hr]
use wetsand paper...much thinner. and if you wanna check out my interior here it is...i used the plasti-kote stuff
and it worked out fine. Came out PERFECT!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
TopFuel's Interior [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 2, 2002
toyzSi's Avatar
toyzSi is an unknown quantity at this point
how hard do u have to push to get the centre peice off. that thing is hard to take out, im scared i might damage something if i apply too much force
Old Jun 3, 2002
dragoon's Avatar
there's 2 bolts holding it in. and also I might add, it's hell to get them off. push up, then when the console's loose, you can pull it out.
Old Jun 4, 2002
Redline01's Avatar
Redline01 is an unknown quantity at this point
Make sure you paint indoors to reduce contaminates. I'd suggest covering your bathroom with plastic wrap and spray painting in there. Also be sure the exhaust fan is on. After you finish a coat, shut the door. Hopefully you won't get too high. [IMG]i/expressions/face-icon-small-wink.gif[/IMG] Make sure you buy plastikote. Its more expensive, but you get what you pay for.
- When you paint you have to prime it first, then wait 30 minutes, then apply 2-3 more coats, waiting 30 minutes in between each coat.
- Try to figure out a way to suspend the peices. This is more effective for spray painting.
- After that, clear coat the peices in the same manner. After you are done, your trim should not peel or crack.
- If you take your time and do it right, you'll not have to waste time re painting your trim.
Take it from me, its easier to take your time and do it right the first time. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
KronikScott
Jun 9, 2015 08:00 PM
DarkCivic
Nov 26, 2001 08:06 PM
EvilTwin
Nov 18, 2001 09:30 PM
BabyLX
Nov 8, 2001 09:25 AM
showmedamoney
Nov 6, 2001 08:23 PM
