neon lights switch wiring diagram
Old May 30, 2002
angjc3's Avatar
angjc3 is an unknown quantity at this point
okay....this is what a switch looks like
1 2 3
does the 12 volt power go to 1 or 2
I think my black light wires will go to the 1 and the 3
is this correct??
Old May 30, 2002
WhiteRabbit's Avatar
flip it to what you want teh "on" position to be. then run your neg to teh switch, and your pos to teh light, and the other side of teh light to the switch.
then just mess around, and clap them onto which ever leads turn on the neon. double check to see hat it will turn back off.
your done.
Old May 31, 2002
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
i'm not really sure what that other guy is talking about, but this is what I did: run your battery to +1 run your positive lead of your neons to +2 .the negative on the light goes to a bolt somewhere on your car, just like an amp. the negative on the switch can be hooked up to a bolt also. if you don't hook up the negative on the switch, the swich won't light up. the lights will, but the switch won't. good luck, don't burn your car down. My Shizzit
Old May 31, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
1= constant 12v
2=power to unit
3=ground
darwin-t
Apr 18, 2015 09:29 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
klam
Nov 16, 2001 03:36 PM
viper775
Nov 15, 2001 10:54 PM
NukeSilo
Nov 4, 2001 09:37 PM
