alignment
Old May 28, 2002
luukass's Avatar
luukass is an unknown quantity at this point
alignment
I just installed ground control coil overs, koni adjustables, and a camber kit on my car, so now is time to get it aligned.
I found a place that will do it but he said If i want I good alignment I need to get the specs for the lowered suspension.
Otherwise he is just going to use the specs for the stock 2001 civic. Did anyone else have this problem and/or know
where I can get the specs I need.
Thanks
Old May 28, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
The stock specs are fine. He can tell you how much you lowered your car too. You do not have to go with the stock Front 0 camber, 0 toe Rear 0 toe, -1 camber, ask others what they have. Mine is Front Toe-0 Camber -.4 Rear toe-0 camber -1. It handles great, but it is up to you.
Old May 28, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Ok...finally found my print out. My specs, with 2" drop and camber kit:
Front left: -0.2 camber, 2.4 caster, 0.03 toe
Front right: -0.2 camber, 2.4 caster, 0.03 toe
Rear left: -1.4 camber, 0.11 toe
Rear right: -1.4 camber, 0.11 toe
Yours might have to be set to a more flexible range, since you have coil-over springs and your ride height will thus vary.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
