ROTATE TIME
Old May 12, 2002
Sosojef's Avatar
Sosojef is an unknown quantity at this point
ROTATE TIME
Does anyone know if rotating your tires by yourself requires you to get the tires aligned?
thnkxs
SIvIKs are cool....
Old May 12, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
I can't remember [IMG]i/expressions/face-icon-small-confused.gif[/IMG] but I am getting mine done this week free rotate at Costco sp I will try to see what they do I know its front to back then next time like side to side
Nick
Old May 12, 2002
CarpeDiem's Avatar
CarpeDiem is an unknown quantity at this point
i got both my 2k1's rotated under 30k and didnt get them balanced or alligned..
They both drive perfect. For the first rotation go from front to back.
It should be fine.
Old May 12, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
changing tires does NOT require an alignment. you only need an alignment if you crash and mess up your suspension, or if you lower your car with springs or coilovers. have fun trying to rotate them yourself though!
Old May 12, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
to assure proper wear of the tires, rotate the front left to the rear right and the front right to the rear left. this produces the same wear as when the tires are in the place they are right now, so no tires wear out before another.
Old May 12, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
not much fun rotating them (front to back only) using 2 jacks... i did it at 10k because I was noticing the uneven treadwear. just easier to take it in and have it done for 10 bucks or whatever
but it does need to be done...
Old May 12, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
my dads best friend own a garage so when i go in to get an oil change he rotates mine when I need it at no charge, so I guess I luck out
Old May 12, 2002
Sosojef's Avatar
KOOOOOOOOOOOOOOOOOOOOO[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 13, 2002
3dStylz's Avatar
3dStylz is an unknown quantity at this point
uhh rotating ur own tires is ez..... acourse I have access to air tools and multiple jacks so that might make a diff..
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
SoCalCIVIC
Dec 10, 2001 12:48 PM
supercivic01
South
Nov 30, 2001 11:27 AM
