Upper Grill?
Old May 4, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
Upper Grill?
is it true that in order to replace the oem grill to an aftermarket mesh grill, it is necessary to remove the bumper to get the job done? anyone done it to their car yet? if it require to remove the whole bumper to remove the stock grill then i will back off from getting a mesh grill then.
Old May 4, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
yea you have to...sorry...[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old May 4, 2002
pounds's Avatar
pounds is an unknown quantity at this point
well you dont actually have to remove it all the way..just do all the places but under the bumper...then just pull the thing down till you can get to the grill.....its very easy
Old May 4, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
it seems like anything you wanna do to the front of your car, you need to take the bumper off.
Old May 4, 2002
Desi's Avatar
Desi is an unknown quantity at this point
- taking the front bumper is really easy to do.
Old May 4, 2002
iamfob's Avatar
really? damn..why so stupid to remove the bumper to replace the grill? this is gaayy...i remembered helping my friend swaping the grill on the 99 civic was like 10 mins job.... anyway if i want to remove the bumper and change the grill, i need to jack the car up to do right? and since i remove the bumper, would u guys recommended i clear the headlight too since removing the headlight would require the front bumper off (i assume)? correct me if i am wrong about the headlight.
Old May 4, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Yup bumpers gotta come off to clear te headlights.
Old May 4, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
I've posted this before and no actually you don't have to remove the bumper-heck I didn't. I replaced the OEM grill with the alteeza. You ned to let your car sit out in the sun for a while. Since the front of our cars is pretty much plastic-the plastic can bend, just becareful but it can be done. If you have the coupe (like mine) the grey plastic piece won't fit back in (this piece is screwed to the OEM grill) even if you take off the bumper. You need to replace that w/ the sedan one or just leave it off like I did and save some $$.
Old May 4, 2002
VNlilMAN's Avatar
The Standard One
removing the bumper is real easy. only takes about 10 mins. i dont think it should deter you from getting the grill. and if you plan on doing the headlights expect to spend an extra 2-3 hours if it your first time.
Old May 4, 2002
Civicster's Avatar
removing bumper is like sooo easy... wuts the deal of taking off a bumper... u wusses
Old May 4, 2002
Mbow's Avatar
While removing the bumper is quite easy, it is a pain in the butt. A just makes a simple mod take a little longer.
Old May 5, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
u dont have to remove the bumper all the way, just remove it partially, just unclip the screws at the top. u dont have to unclip the screws on the bottom. pull it out halfway, then switch the grills and screw it in. thats what i did
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
rnaodm
Sep 21, 2015 12:42 PM
FistRock
Sep 4, 2015 08:00 PM
