HELP WITH COILOVER INSTALL ASAP
Old Apr 26, 2002
3dStylz's Avatar
3dStylz is an unknown quantity at this point
I need help removing the old strut I am having problem removing the bolt connecting the strut to the bar that turns the wheels, I have the pin off, and the bolt off but it still wont come off anyone who has done this please help imediatly
thank you
Old Apr 26, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Do you mean you have the nut off ? Not the bolt. Thread the nut back on until the nut is flush with the threads (this protects the threads from getting damaged) and get a hammer and hit it upwards driving the joint up and loose.
Old Apr 26, 2002
3dStylz's Avatar
for the lower two bolts right?? I am having problems with the upper one in there that connects it too the steering I am scared to hit that with a hammer it moves too much
Old Apr 27, 2002
BAK's Avatar
BAK
You're talking about the tie rod end aren't you ? It is tapered, you will have to either get a special tool for removing it or thread the nut back on and hit it with a hammer upwards to drive the end up and out of the fitting. Just be careful. Also, don't let the hub drop dowm too much, it will pull the drive shaft out of the trans and it can be a biotch to get back in.
Old Apr 27, 2002
BAK's Avatar
BAK
Also, I would take the steering tie rod off first ( hit it upwards with a hammer with the nut on the end to protect the threads). Then undo the brackets for the ABS and brake lines and move them out of the way. Then undo the 2 bolts that hold the strut to the hub assy. Then undo the three nuts in the engine compartment to drop the strut down.
Old Apr 27, 2002
3dStylz's Avatar
well I have an LX so no abs but I already have all the other nuts and bolts off and just cant get that one to come free, I have no Idea I hit it with a hammer and it didnt loosen up
Old Apr 27, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
yeah take off the steering tie rod, and if you dont haev ABS then dont worry about it.
Old Apr 27, 2002
BAK's Avatar
BAK
You should have seen a PM by now. I would put the two bolts that hold the strut to the hub back in and the three nuts that hold the strut to the tower back on to steady up that strut so you can get a good clean hit on the steering tie rod end. One of mine came up and out easy, the other took some force, but if you are careful, you won't damage anything.
Old Apr 27, 2002
VNlilMAN's Avatar
The Standard One
the way i did it was i rented a tie rod seperator from autozone(you pay $15 deposit n they refund it back when you return it). it only took me like 15 seconds. you just hammer it in, lean on it n bam it comes off. dont worry about ripping the boot, its only like $1.50. oh n remember to jack up both sides in order to get the strut back in. i had to learn the hard way.
GolNat
Jul 15, 2015 03:42 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
