Power Window Not Working!
Old Apr 21, 2002
Grey's Avatar
DIY King
Refer to this thread: Where is(are) the power windows fuse(s)?
Now, I also tried a voltmeter up to the wire that leads to the power window motor. I set it on lower settings and higher settings. I played with the power window switch. Nothing. No readings. I still have to compare it with the other side (that works) to see if I'm checking it correctly. Anyway, any ideas?
Old Apr 21, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
i noticed that my pass. side window has gotten loud and whiney sounding when i roll it up. i wonder what is up?
Old Apr 21, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
My dad had the same problem with his 2k1 accord v6 i am not sure exatly what he did but he replaced the windows motor
Old Apr 21, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
I also have a problem
my left doors lock wont open all the way
is there i way i can fix this
it always goes half way and doesent open fully
but this is on my dad's CR-V its a 98
so how the fu*k do i fix this?
Old Apr 21, 2002
its annoying because its a daily driver
Old Apr 21, 2002
1973's Avatar
1973 is an unknown quantity at this point
all that power sh*t is just headaches...just wait till the cars are 5 years old......
Old Apr 21, 2002
Grey's Avatar
DIY King
Okay, I think I have this problem licked. I checked all of the connections with a voltmeter and it seems that the passenger side switch is getting power, but is not passing it on when it's triggered. Defective switch. I'll take it apart and see what's up.
<< I also have a problem
Yeah, same with mine. I think this happened after I took apart the interior door panel the first time though. I don't know how to fix it yet, but I'll see what's up soon enough.
Old Apr 22, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
grey? why dont u just take it to honda and let them molest it for you?
Old Apr 22, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Grey, I know you checked the fuses but did you check all of them? I haven't checked on my Civic but my Accord had seperate fuses for the right/left windows. I really made me made because I was installing a 530T window module. I had everything all put back together and then my drivers side window wouldn't work. I took it all apart checked all my wires, checked my fuses, then I realized each windows had a seperate fuse.
nevermind, just read the post that you linked to
Old Apr 22, 2002
Grey's Avatar
DIY King
<< grey? why dont u just take it to honda and let them molest it for you? >>
Because more than likely I'de have to pay for it since I modified the interior of my car so much. I took out that vapor barrier and I glued sound deadening material all over the place. I'de like to solve this problem myself.
Okay, I had a defective voltmeter. I replaced the fuse within the voltmeter and then I took accurate readings. It seems the power window switch and the wire leading to the motor deliver the power properly. This sucks. It looks like it's the power mirror motor itself. I wonder what the hell caused it to burn out?
OMFG! I am so dense! Guess what it was? It was the damned switch on the drivers side. That damned switch that you press to block the passenger side window. I assumed that I could control the passenger side window from the drivers side with that switch depressed or not. Assumptions are the mother of all Fups. Do I feel like a bone head. Oh well, I needed to take off my door panels to finish off the insulation anyways. [IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 23, 2002
AlexLx's Avatar
AlexLx is an unknown quantity at this point
ha ive had a couple of 2 second scares with that two. [IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 23, 2002
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Sup Grey,
Yo man, I had that problem in my Integra... It may be a different problem for you but I found out that it was the switch piece, it may be different in our cars, I haven't checked- but- it's the piece where the wire harness connects to the switch piece ( i dunno the name) but the one on the door. Anyway, I went to a junk yard and got a repleacement dirt cheap. I think something inside cracked from all the door slamming, etc... Hope you figure it out!
-RoBB
Old Apr 23, 2002
Grey's Avatar
DIY King
I did figure it out. Read my last post. Especially the end of it. [IMG]i/expressions/laugh2.gif[/IMG]
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
got2kids
May 9, 2015 06:45 PM
ORskier
May 3, 2015 12:54 PM
