remove rear bumper cover
Old 08-31-2010
bighead's Avatar
bighead is an unknown quantity at this point
I have a 2008 civic coupe that had the rear bumper bumped. Now I need to remove the cover for access to area around tail light and bumper clips. I would appreciate information on removing cover from some of you experienced in this. thanks
bighead is offline
Old 08-31-2010
Live for the Twisties
MindBomber's Avatar
Re: remove rear bumper cover
I haven't removed an 8th gen bumper, but I can do a basic DIY on the 7th gen bumper for you; I'm not sure how much of this will apply to the 8th gen, but this should give you an idea.
1: Locate the two black plastic caps under the bottom lip of the trunk, and carefully pry the caps off. Under each cap you will find a 10mm bolt, remove them.
2: On the underside of the bumper cover you will see two black clips, with a flat head screw driver carefully pry the center tabs out and the clips should slide out.
3: There is one screw on the inside of each wheel well, remove them with a phillips head screwdriver.
4: Everything fastening the bumper cover on is now removed. Slowly work your way around the upper edge of the cover and it will pop off.
MindBomber is offline
Old 08-31-2010
iallan's Avatar
iallan is an unknown quantity at this point
Thanks for this! I was just going to figure it out but now i dont have to. Good pics too!
iallan is offline
Old 08-31-2010
MindBomber's Avatar
Glad I could help.
OPGForce
Exterior DIY
125
05-20-2019 04:11 PM
usajags84
15
08-19-2015 03:12 AM
Mercilus
06-07-2015 10:00 PM
Quick Reply: remove rear bumper cover
