2001 timing belt tensioner bolt wont tighten up?
Old Aug 12, 2010
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
I have a 2001 Honda Civic LX and I changed the timing belt and on the tensioner the bolt wont tighten up cant even get close to 33lb. When I took the bolt out it has shaving on the bolt. Is their any thing to put on the bolt or what are my best options ? Thanks
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
Re: 2001 timing belt tensioner bolt wont tighten up?
If shavings are on the bolt after you take it out then you are striping the threads on either the hole or the bolt but most likely both. This will be a easy fix though. Go to autozone and buy you a tap and die set. Get it out and have the bolt and find out what thread it is. Grab the right die and retap the bolt and also retap the hole where the bolt goes to and then try that.
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
