rear bumper and tail light housing replacement
Rep Power: 0 rear bumper and tail light housing replacement
I parked my car at LAX airport parking. When I came back someone hit the rear drivers side corner of the bumper (dented inward with paint cracked off) and cracked that tail light.
Does anyone have a diagram of how to dismantle the bumper and tail light?
I searched online and found replacement bumper for $271. They are not painted. What is the best approach to getting it painted? Do they sell them somewhere with it already painted?
The driver's tail light sells for $73 online. The hairline cracks is on lower part of light. It is has a tiny shard missing (size of dime).
2005 Honda Civic, 2 door Coupe, Value Package,
Exterior Satin Silver Metallic
1.7 Liter engine
The other way instead of replacing is try to hammer that dent out and fill it and then paint. Maybe find some plastic filler for the crack on tail light.
All advice welcome on approach and info on DIY. Thank you!
1.7 Liter engine
1 Post
Rep Power: 329 Re: rear bumper and tail light housing replacement
buy the tails online. they are cheap. 3 screws in back and the taillight comes right off.
as for the bumper, there are a few clips on the bottom and some near the taillight and some on the side. there is the DIY on here somewhere. search is ur friend.
Rep Power: 0 Re: rear bumper and tail light housing replacement
as for the bumper, there are a few clips on the bottom and some near the taillight and some on the side. there is the DIY on here somewhere. search is ur friend.[/QUOTE]
Thank you sl33pyriceboi. I will order that tail light online. The DIY diagram for rear bumper located and printed out. When asking around - they said this OEM bumper is not painted. Should I check around for someone to paint it? Reading through forums I found a online paint supplier that has the exact paint color for my Civic. Another member mentioned that he did some paint blending. The paint blending looks complicated without good equipment and practice. How would you go about this?
I'd say just get color matched paint for your car and car clear coat and paint the bumper yourself. Usually they already have a primer on them.
I will give it try. Please clear up for me - how to paint it? Do I rent a sprayer from home depot? or use spray can or brush?
So color blending is not needed here?
Received 1,160 Likes
Rep Power: 486 Re: rear bumper and tail light housing replacement
you can buy a rattle can of OEM paint from automotivetouchup.com...
yup. I just ordered a can of EBP and a can of clear for my car
post up pics after you're done
Or if you live close enough to san diego, and you don't mind leaving your car for a bit, I know a guy that does good work for relatively cheap
shaejb15
04-12-2015 11:38 AM
