07 si spark plugs
Old Mar 29, 2010
Dav07Si's Avatar
Dav07Si is an unknown quantity at this point
07 si spark plugs
I need help on how to change my plugs! Help please! Lol
Old Mar 29, 2010
02civicsi02's Avatar
Low and slow!
Re: 07 si spark plugs
Its very easy to do.
Tools needed:
Socket wrench set
Very long socket extension
Spark plug socket or just a socket that fits the spark plugs and use the ciol packs to get them out.
and of course you need spark plugs.
First pop the hood. Then remove the acorn nuts holding down the spark plug cover. Then take the 2 bolts out of the 2 coil packs that have them. Unplug the coil packs and take them out. Get your spark plug socket and the extension and put it down the hole and loosen the spark plug then pull it out and put the new one in and continue that process till you are done with the spark plugs. After you are done put everything back together. Its just common sense really.
Old Mar 30, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Do not over tighten them.
Old Mar 30, 2010
lowlife9's Avatar
u should be very careful not to strip the threads when you put them back in and use a torque wrench to torque them down different plugs usually have different specs.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
