Whining noise during acceleration.
Old Mar 3, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
I've had this since I bought the car 4 years ago and I could never figure it out. If I press the gas, I hear a whining noise from the engine compartement. If I let go of the gas, the sound goes away. If I'm idleing and reving in neutral, there is no whine.
Old Mar 3, 2010
hwt101's Avatar
hwt101 is an unknown quantity at this point
Re: Whining noise during acceleration.
supercharger?
Old Mar 3, 2010
lowlife9's Avatar
alternator whine maybe ???
Old Mar 3, 2010
94EGhatchLUV's Avatar
94EGhatchLUV is an unknown quantity at this point
mine does the same thing i think its the alternator
Old Mar 3, 2010
Saroset's Avatar
Saroset is an unknown quantity at this point
Yeah, I'd go with alternator as well. I have a persistent grinding noise from the alternator that only appears in drive or reverse.
Old Mar 3, 2010
ive heard that sound before from a worn timing belt tensioner. sounded exactly like a supercharger whine and increased frequency with rpms. changing the tensioner fixed it.
Old Mar 4, 2010
Oh ****, I had that grinding noise too. It went away for some reason but still. Yeah it's gotta be alternator. But... what does it mean that it's whining/grinding? And why does it only do it when in gear and not in neutral reving?
Old Mar 4, 2010
My tensioner was replaced at 115k though along with water pump, timing belt et cetera.
Old Mar 4, 2010
Marxx's Avatar
Marxx is an unknown quantity at this point
Try this..This is how to diagnose it.....INPUT SHAFT BEARING
-Start your car.
-Roll up the windows, turn the radio off, and turn the blower motor for the AC/heater off.
-put the car into neutral, and take your foot off the clutch pedal
---- if you hear the noise now, it is the INPUT SHAFT BEARING. if you press in the clutch, the noise should go away.
Old Mar 4, 2010
I already replaced the input shaft bearing, and I've even run a different transmission. It's not transmission related. But thanks.
Old Mar 7, 2010
Gearbox, can I test the alternator by taking off the belt and driving it to see if the noise is gone? I think this is the real reason for my power issues, as the coil didn't help so I'm taking it back.
Old Mar 7, 2010
yeah, just dont drive very far.
Old Mar 14, 2010
I check the voltage from the battery with the engine on, it reads 13.7v. Isn't that a little low?
Old Mar 14, 2010
97EK's Avatar
97EK will become famous soon enough
Is it a whine or more of a whistle? D16Y7's are known to have a slight whistle from the throttle body under acceleration. I noticed the whistle on mine got a little louder once I put a K&N filter in. I can only hear the sound while driving/accelerating just like you.
Old Mar 14, 2010
It's more like a whine I would say.
Old Mar 15, 2010
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
i heard the same problem in my civic. thought it was alternator but found out it wasn't (the belt broke off the alternator oops!) and it is the tensioner for me. i'd imagine that dirt and general age use/abuse can make the bearing the alternator pulley spins on wear out just like any other part on your car that sees service
Old Mar 15, 2010
I just don't have time to test it now. But I'm wondering if one of you guys can hook up a multimeter to your battery while the car is on with no load and post your voltage, because I don't know if 13.7 is on the weak side.
Old Mar 16, 2010
^Warranty voider
my voltage gauge in my car says 14 volts when i have the car running so i guess thats normal
Old Mar 16, 2010
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
The sound that I had coming from my car was also "whining sound". After months and months of research I found out that it wasn't the isb or the alternator or the transmission...The problem was that my alternator/serpentine belt was not properly tightened.
The way the belts are supposed to be tightened are first use the tensioner to tighten(butterfly ****) then screw it down to lock.
Once you screw the bolts in, tightening the butterfly ***** any further does absolutely nothing to tighten those belts. Once I loosened the bolts just enough to allow the butterfly ***** to actually tighten the bolt, the belts tensioned properly. Rule of thumb, you should just barely be able to turn the belts 90 degrees if you don't have a belt tension guage.
Again, I spent months researching this same topic and almost did some major work on my car, aka isp, new clutch, alternator(failed right after I diagnosed the sound Hehe!) After I properly tensioned, the noise never came back. The noise was always there too, when it was cold, in the mornings, when I would rev my engine, when I was in first, second, and third gear building up momentum. Lets just say I was very relieved when I found out where the sound was actually coming from
If you have any questions feel free to pm me.
Old Mar 16, 2010
Thanks JD. I doubt that's it but I will look into it and other possibilities.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
NROD315
Sep 4, 2015 09:22 PM
dantheman42
Sep 4, 2015 01:10 PM
