Help with clutch
Old Feb 14, 2010
02civicsi02's Avatar
Low and slow!
Help with clutch
Ok guys i am not to knowledgeable about this stuff but i know a little. But anyway i have a 2002 honda civic si and well the clutch pedal use to let out at the 1/4 the way off the floor but now its more like 3/4 the way from the floor. It lets off toward the top now and its getting annoying cause it kinda harder to drive. But what is wrong with it. Does this mean i need a new clutch or what.
Thanks in advance.
Old Feb 14, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Help with clutch
Adjust your master cilinder pushrod to compensate for the wear. Loosen nut, twist rod with finger so the pedal is lower. Then adjust the stop bolt. There should be half an inch of play, but you can even do less.
I wouldn't even mess with it though. It's better to have the engagement up high because the lower the engagement point, the more abrupt (less smooth) the clutch will engage, making it hard to drive.
Sounds like you need a new clutch though.
Old Feb 14, 2010
Low and slow!
Thanks for the post. And ya i was kinda thinking bout adjusting the pushrod but i heard that it wears out the throw out bearing fast. But i might just adjust it alittle not to much though. And ya i was thinking i might need a clutch i have 90k on my ep3.
Old Feb 14, 2010
I don't know what the deal is with the pressure plate. It's self-adjusting to a point, but then after that the pedal starts to engage high?
Old Feb 15, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
it can only compensate so much before you start to feel the effects
Old Feb 15, 2010
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
My clutch lets out about 3/4 before it catches aswell so a new clutch may be coming but when ur clutch has nothing left it typically starts slipping- Revs dont match acceleration.I'm not slipping at all and I'm easy on the whip so I think I've got more time. All depends on ur driving habits/previous owners I guess.
Old Feb 15, 2010
Low and slow!
Ya sounds like i need to get a new one cause sometimes it gets hard to drive.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
