Quick Crank Pulley Bolt Removal Question
Old Dec 31, 2009
Frackadoxs's Avatar
Frackadoxs is an unknown quantity at this point
All,
Going to replace the timing belt on the wife's 2002 Civic. Looks like breaking the crank pulley bolt is the most difficult part. My question is can you use the starter to break the bolt loose? Basically place the socket onto the bolt, brace the breaker bar (remove coils to prevent starting) and engage the starter to break loose the bolt. I have used this technique for brecking loose the crank bolt on my Toyota, not sure if it will work for a Honda.
Anyone try this before?
Also, I am unsure of Honda's direction of rotation and firing order.
Thanks!
Old Dec 31, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Quick Crank Pulley Bolt Removal Question
I don't know, but I just used a 24" breaker bar and jack stand like in this video. Someone mentioned on here that you can loosen it before you do anything else by keeping one of the wheels on and keeping the engine from turning. So I guess that means putting it into first? If you go this route here is a demonstration.
http://www.youtube.com/watch?v=RE-pzP8g_x4
Old Dec 31, 2009
Frackadoxs's Avatar
Thanks for the response. Problem is I do not have the pulley tool and the car has an automatic transmission.
Not wanting to pull the starting and jam the flywheel, was looking for an easier way of breaking loose the pulley bolt.
Old Jan 6, 2010
wardhaines's Avatar
wardhaines is an unknown quantity at this point
I believe all hondas rotate counter clockwise. Wouldn't that tighten the bolt if you used the starter?
Old Jan 6, 2010
I'm picturing that it would.
Old Jan 15, 2010
wardhaines's Avatar
I just did this over the weekend. Mine took a 3ft. breaker bar.
You need the crank tool to stop crank from turning. Believe me, the best money sent if you only use it once.
I have used it 3 times so am way ahead.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Flipg123
May 22, 2015 10:43 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MooCoW
Nov 9, 2001 05:22 PM
