radio wiring
Old Dec 29, 2009
laack's Avatar
laack is an unknown quantity at this point
radio wiring
the guy who owned my car previous to me botched the install of the cd player. the cd player/radio doesnt turn off when the ignition is turned off. I have to manually power it down every time i get out of the car. at some point i am sure to forget and run the battery down. I expect to find a missing ground wire when i open it up, but i'm not a real genius when it comes to wiring. what am i looking for? does that sound like a decent guess?
Old Dec 29, 2009
CraigW's Avatar
Re: radio wiring
If aftermarket he most likely tied the "switched power" lead to the "constant power" source.
Most switched power leads are red with an inline fuse holder & constant power/memory is yellow with a inline fuse holder also. (yours may be different depending on brand)
I had mine wired like that for a short time, then switched it back. Never knew if I turned it off or not.
Old Dec 29, 2009
stock03's Avatar
stock03 is an unknown quantity at this point
Re: radio wiring
I used to wire my stereos to a constant 12v source so I wouldn't need a key to listen to the stereo when working on the car. But I have accidentally left the radio before and ended remembering after many hours when the battery is dead.
Old Dec 29, 2009
04 Honda Civic's Avatar
Re: radio wiring
This is more then likely what the case is. Many people don't realize that there is two different wires. One constant and one with ignition only. Its really easy to fix. All you need to do is undo the ignition wire from the radio from live at all times and connect it to the ignition wire that is hot only when the ignition is on. Its really that simple.
magog45
Jul 9, 2015 06:23 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
