Need some ecu info for a swap
Rep Power: 214 Need some ecu info for a swap
ok, my neighbor has a 92 accord, i know this is a civic forum, but he really needs some help and i couldnt answer his question cause ive never dealt with ecu's much. So i thought id ask you guys cause somebody has to know. anyways its a 92 accord that had a f22 NON-vtec in it to start with, well he blew his motor and ordered another f22 but this one is a vtec...sohc. the engine code on the new motor is f22b1. now i know SOMETHING will have to be done with his non vtec ecu right? so it can run the vtec in the new motor? will this require a complete ecu swap or what? thanks for any info
Rep Power: 788 Re: Need some ecu info for a swap
he needs an EX vtec ecu for starters, then the vtec solenoid needs to be wired from engine to ecu so the vtec works. the old oem harness will not have the vtec wire already installed. some people use a VAFC from apexi to control the vtec and tuning instead of a new ecu, but this is not a reliable solution and requires dyno tuning. easiest way is find a used EX ecu. then you need to check the wire diagrams and see which wires you need to add.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
McD
04-22-2015 05:28 PM
supercivic01
26
01-26-2002 10:11 AM
