7th gen foglight problem - only 1 lights up
Old Jul 13, 2009
em2_pl's Avatar
em2_pl is an unknown quantity at this point
EDIT - Sorry, wrong section. Can someone move this? thank you!
Alright, I posted a thread a week ago about the 7th gen DIY here and it didn't work out for me (switch didn't work and other issues) so I followed this one:
http://www.clubcivic.com/board/showt...=169383&page=2
Everything connected just fine (switch lit up and turned on) but the left fog light (right if you're looking at my car from the front) will not turn on.
So, I ended up replacing the light bulb and both bulbs work on the right side.
The ground wire (black) is connected and the power (yellow) is connected to the endpoint of the fog light harness (which connects to the sub-harness). The
only thing I can think of (I'm a total noob at car mechanics/electrical - so
I'm waiting for my father) is the socket thing that the light bulb connects to?
Would there be any electrical stuff in the car that would prevent it from working? I'm assuming no because it's just a power cable.
Thanks guys for any help!
Old Jul 13, 2009
LT2004ever's Avatar
I wil fix vBPlaza today
Re: 7th gen foglight problem - only 1 lights up
my guess is the connection. if only one lights up, i doubt its the relay or a fuse. You replaced the bulbs, and checked all the grounds... durn.
My suggestion is to cut your lights on then start wiggling all the connections, and taking them apart, then re attaching them. Just to to see if the light flickers or not.
Old Jul 13, 2009
em2_pl's Avatar
Thanks for the reply!
I'm totally stumped. I checked all the connections and they *should work - the connection to the left fog light even has power (check using the tool where you connects it's ground and then touch an open wire. I took the left bulb out and even seen that it's getting current through it's connector.
The fog light harness has both wires connecting to one (which looks fine) and this connects to the subharness. So, I'm not sure where I should try next.
Old Jul 13, 2009
Hanzo's Avatar
Hanzo has a spectacular aura aboutHanzo has a spectacular aura aboutHanzo has a spectacular aura about
Should be the ground for that side. just make sure its connected down all the way and make sure its real tite. Not enough contact will cause it not to light up.
Old Jul 13, 2009
em2_pl's Avatar
I actually tried that as well. Even cleaned up where it states to connect it.
Old Jul 13, 2009
Hanzo's Avatar
hmm thats wierd. The only thing i could suggest is to make sure everything is wired up correctly. Check ALL connections. If not could be relay..
Old Jul 13, 2009
em2_pl's Avatar
That's seems to be an option but it would be weird considering there is power going to it. Not only that but the sub harness (one internal wire) is then split into two (the fog light harness).... so I'm not sure why a relay would have anything to do with the "split" of power/current.
I'll look into it some more but thanks for your input.
Old Jul 13, 2009
em2_pl's Avatar
Hanzo, you were right - it's a grounding issue.
All these hours lol.... wasted.
It seems as if the area to be grounded (as per all instructions) was painted over and no contact was made. That's it and that's all.
I feel dumb but thanks guys for your help.
Old Jul 13, 2009
DanielsSTEK's Avatar
DanielsSTEK is an unknown quantity at this point
If it's anything like my 6th gen fogs (and most would be), it's not the relay because that would cause both lights to shut off... a relay is basically a switch controlled by electricity, and it allows current to go through (to both lights, as you stated)... like everyone else, I can't imagine what it would be other than the connections. If power is going to it, I recommend rigging a connection for the bulb from the wires, and it should work (your dad or someone could probably help you out with that). Sorry I don't have any better ideas, and good luck!
Old Jul 13, 2009
Hanzo's Avatar
haha your welcome EM2. Yeah i had that problem when i installed my recently. Turned out i didnt bolt the ground down tite enough.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Lt. Dan
May 13, 2015 12:42 PM
pheaton
May 4, 2015 08:26 PM
Myredjonda
Apr 14, 2015 07:00 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
