Alternator issues
Old Jul 11, 2009
Burnindesirez02's Avatar
Burnindesirez02 is an unknown quantity at this point
Alternator issues
My alternator went out...at least i thought...took it to pepboys to test it and they said it was fine...so i brought it back home and put it in my car and it still doesn't charge my battery...i bought new battery terminals and they still didn't help it...i bought a cheap alternator test kit and showed that it was 12 volts while running..but i know it should be over 13...i have a 96 civic ex with a swapped B16A jdm engine...any help would be appreciate..thanks
Old Jul 11, 2009
One_Fit_Civic's Avatar
One_Fit_Civic is an unknown quantity at this point
Re: Alternator issues
well that sucks have you changed your old battery, and trust the pepboys guys they know their **** but other than a bad battery i couldn't tell you where to go next
Old Jul 11, 2009
maybe gearbox could shed some light?
Old Jul 11, 2009
battery is fine...i can trickle charge it and it starts up fine...its also the Optima Yellow top battery...i know its not the battery...thanks...
Old Jul 11, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Does the car shut off when the battery is disconnected?
Old Jul 11, 2009
yep...
Old Jul 11, 2009
might be loose wire between alternator and battery. make sure the power wire is tight on the alternator side, ive had mine get loose over time. and have it tested somewhere else.
Old Jul 11, 2009
well i fixed the alternator..don't know how but changed all the fuses and put them in the right places...but now i have another problem...i have no vtec and im idling at 2500 rpms...but im just wondering if that could be because the alternator is in full output...
Old Jul 12, 2009
sparkplug's Avatar
sparkplug is an unknown quantity at this point
engine oil level ok?
Old Jul 12, 2009
it is a little low...would that have to do with either of those?
Mike Garvey
Jun 7, 2015 07:25 PM
Black91civic
Jun 6, 2015 08:15 AM
HiImBrandon
Jun 1, 2015 07:34 AM
jackoncruzpr
May 24, 2015 12:24 AM
Derek-CEO
May 5, 2002 02:08 AM
