LOWERing problem!!!!!!
Old Apr 12, 2002
JDQuikCivic's Avatar
JDQuikCivic is an unknown quantity at this point
Hey guys, I just lowered my car with H&R springs. I noticed that my passenger side is a bit higher than my driver side. I measured about a 1/4 to 1/2 inch difference between both sides. Anyone have this happen to them before. I'll give it a week to settle in abit more and hopefully it levels out equally. Any ideas in what would make this happen?
Old Apr 12, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
Dont you have to cut some of the rubber stops off? If so maybe you didnt get both sides even i.e. you took too much off one side.... but I dont know so just my 0.02
Old Apr 12, 2002
TOOLOWCIVIC's Avatar
Maybed when it settles it will be even[IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 12, 2002
avenger's Avatar
avenger is an unknown quantity at this point
the eibachs on my dad's 3.2tl did that, went away after about a week
Old Apr 12, 2002
What rubber stops. Everything fit in perfectly. If you have to cut the rubber, what part and how much?
Old Apr 12, 2002
I dont know I just thought I read somewhere someone saying that they cut a little of the rubber stops
Old Apr 12, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
He is talking about the rubber bump stops. You have to trim them so when your car is lowered it won't bottom out(on certain applications) They are on the end of your shock
Old Apr 12, 2002
andoy's Avatar
andoy is an unknown quantity at this point
hey.. i have thesame problem... my car is lowered with NEUSPEED RACE springs and my passenger side is like .25 inch higher than driver side... its been like that for about 1.5 month.. i dunno.. still thesame.. umm.... but if a passenger sits in front or back.. it all evens out.. i dunno.. i went to ask if this is normall they said.. many civics (2k1) has those problems.. but.. i'll just leave it alone cuz.. its not much of a dif.. just knowing kills me the most cuz i paid install.. and if they didnt do it properly.. then.. [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
hope this helps!!!
Old Apr 12, 2002
Bartkat's Avatar
The bump stops are to be cut back about an inch. But the stops don't come into play unless your springs and shocks bottom out. The stops do nothing when the car is just sitting.
Old Apr 12, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Yeah, the bump stops wouldn't cause it to sit crooked.
How much have you driven your car since the install? Have you moved it at all?
Maybe the springs were made to where the drivers side is a bit higher than the passenger side and things even out when the driver sits in the car? And you just put the wrong springs on the wrong side of the car... [IMG]i/expressions/laugh2.gif[/IMG] lol, I don't know.
Old Apr 12, 2002
All the springs that I have on are all the same size. Do you think that if I take the rear passenger spring and switch it with the drivers side would it even out a little bit? Oh yeah, where are the bump stops located?
Old Apr 12, 2002
MexMike's Avatar
MexMike is an unknown quantity at this point
I got eibach sportline springs and a few people have said it looks lop-sided but i don't see it. Most peopel say it is even. Maybe they are just ****-eyed. No offense to those of you who are ****-eyed.
Old Apr 12, 2002
AEMcivic's Avatar
<< Oh yeah, where are the bump stops located? >>
follow the red arrows....
Old Apr 13, 2002
pr0ph37's Avatar
pr0ph37 is an unknown quantity at this point
are the coil overs adjustable if so just drop the high side another quater inch
Old Apr 13, 2002
Bartkat's Avatar
i follow the red arrows....
Yep for the struts that's it.
Item 16 is the bump stop for the rear shock.
Item 8 in this drawing is the bump stop for the front strut.
GolNat
Sep 10, 2015 08:25 PM
vtec_concept
May 24, 2015 10:27 AM
jdawgzcivic
May 20, 2015 08:14 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dooner24
Apr 14, 2015 07:51 PM
