front hood deflector....take it off or leave it on???
Old Apr 12, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
i got a hood deflector from factory with my LX-G and it seems to be the thing that makes my car look
like the other ones i see the most . i was looking at it if i take it off i see little rubber stoppers on the hood
itself looks like it's stuck on the hood does anybody know how i can take them off? maybe it's some Glue and i would
mess up the paint hmmm.
Old Apr 12, 2002
ZZCIVIC's Avatar
ZZCIVIC is an unknown quantity at this point
You could probably remove it with some heat. Use a hair dryer and heat up the glued area, see if it looses, then just take it off. That's the way you shave off the emblems on the rear, they are just glued on, so it should work on those as well.
Old Apr 12, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Yeah I would take it off man, looks cleaner. Give those little stops a bit of heat from a hair dryer and they should lift off fairly easy.
Good Luck
Old Apr 12, 2002
Heylerds's Avatar
Heylerds is an unknown quantity at this point
I took mine off, also had the factory thing, well anyways I just moved it back and forth until its out (the rubber stopper), it will leave some sticky thing on the hood but I removed with baby oil and thats it.
usajags84
15
Aug 19, 2015 03:12 AM
TiggerDX
Jun 18, 2015 01:43 PM
ibilalx
Jun 17, 2015 11:00 PM
crowtoo
May 11, 2015 06:50 PM
Grey
16
Jan 27, 2002 11:34 PM
