02 Rsx Type S seat install question. Yup I did use search and read
Old Jun 7, 2009
Ruamit03's Avatar
Ruamit03 is an unknown quantity at this point
Hey guys,
So i came across pair of 02 Rsx Type S seat that were a steal and I couldn't walk away from them. Well I got the seats so after cleaning them up, I looked under neath the seat and there are four plugs. The Big yellow one and blue one and two more. There's also two male plugs there too. So should i just connect them? Also should I switch the seat belt harness from my stock one into the rsx seat. Thank you for you your help.
Just noticed that the plugs I am talking about are only underneath the passenger seat, not the driver seat. Here are some pic's
http://i659.photobucket.com/albums/u...3/IMG00039.jpg
http://i659.photobucket.com/albums/u...3/IMG00040.jpg
Old Jun 7, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: 02 Rsx Type S seat install question. Yup I did use search and read
Plug in the plugs from ur car to the plugs on the seat. leave the other ones unplugged, they are probably for side airbags and ur car probably doesnt have side airbags.
Old Jun 7, 2009
LT2004ever's Avatar
I wil fix vBPlaza today
yeah one of them is for the side airbags
how much you get them for???
did you just get the front two, or a whole set??
Old Jun 8, 2009
Ruamit03's Avatar
I drove down to PA this weekend to pick them up. It was 200 for front two. Also should i exchange the seat belt assembly? Thank you guys.
Old Jun 14, 2009
Civilized05's Avatar
Civilized05 will become famous soon enough
I just had a friend install my 05 rsx front seats. No seat belt component needs to be changed, as long as the RSX seats come with the female buckels.
But, do not forget to disconnect your battery before unplugging the plugs under the seats. I didn't read up on that part, and now my SRS light is on.
There's a thread to reset the SRS indicator, in case you've already disconnected the plugs. However, I've done the steps 3 or 4 times (with a paperclip) to turn the damn light off, but it's not working. So, I'll give it another try some other time.
Old Jun 15, 2009
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Yes, replace the rsx seat belt assembly with the civic ones. It is a direct swap. You may want to consider getting some spacers for the rear bolt closest to the center consol (both passenger and driver). Otherwise your seats are a little bit slanted.
Old Jun 15, 2009
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
replace seat belt assembly with the civic ones
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Blazz
May 25, 2015 10:56 PM
bsmiley
Apr 27, 2015 01:27 PM
Vtecpwr
Nov 11, 2001 10:17 PM
