Anyone install fuel pressure meter???
Old Apr 11, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Has anyone installed one of these, and if so since we have non-fuel return system does that make a diiference with anything?
Old Apr 11, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
i think if you have an electric fuel pressure guage,you just cut the fuel line and put the sender between the line.
Old Apr 11, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The purpose of a fuel pressure gauge is to monitor the amount of fuel going to your injectors. The reasoning being that rate and pressure affect total volume. If the pressure suddenly drops, then that is a huge indicator that you are running really lean to your injectors. This is a pretty important add on when you do serious work like adding a turbo.
For safety, I would recoommend an electric gauge. It simply goes between the fuel rail and fuel pump. The sender should be mounted in the engine compartment. So if fuel leaks out, it has somewhere to go. Then you can mount the gauge anywhere in the car.
Jonnie.
Jan 13, 2019 11:21 AM
mrcell24
May 19, 2015 10:02 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
MooCoW
Nov 15, 2001 10:58 AM
