1996 honda civic ex automactic swap to manual
Old Feb 23, 2009
jimmezero's Avatar
jimmezero can only hope to improve
hey, im swapping my auto to a manual. its a 96 civic ex. i just want to know what do i need to do the swap? im going to put the same motor but its gonna be a manual thats it.
Old Feb 23, 2009
SITNLOW97's Avatar
SITNLOW97 will become famous soon enough
Re: 1996 honda civic ex automactic swap to manual
First off u need to use the search button...
Old Feb 23, 2009
pacotaco's Avatar
pacotaco is an unknown quantity at this point
Originally Posted by sitnlow97
first off u need to use the search button...
hahahahahahahh
Old Feb 24, 2009
jimmezero's Avatar
sitnlow97---- shutup if u not giving advise about this ok.
Old Feb 24, 2009
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Come on man, he's right. This is something that is pretty easy to find information on. You can't expect everything to be spoon fed to you. I'll get you started though...
You need quite a bit to do the swap, so it's not an easy 1-2-3 answer. Start with the obvious ones like the transmission, pedal assembly, center console, shift linkages...and then do some research for the specific stuff. Prepare to spend at least $600-800 (that's if you're good at finding parts for cheap!).
Old Feb 24, 2009
bakertime's Avatar
Ugh, Double post.
Old Feb 24, 2009
jimmezero's Avatar
yea i got all that already. juz need more info cuz this gonna be my first swap that im doing.
Old Feb 24, 2009
ramonjones16's Avatar
ramonjones16 is an unknown quantity at this point
You need the tranny, ecu, slave cylinder, clutch cylinder, shift linkage, pedals, chances are if your getting used parts you might want to replace the clutch and flyweel depending on how many miles, center console setup(includes multiple things) look it up on google, alot of time and fustration with tuning and yeah....
Old Feb 24, 2009
bakertime's Avatar
http://lmgtfy.com/?q=Civic+auto+to+manual+swap
The second link is the most detailed description you'll find I would guess...Took 30 seconds to find.
Old Feb 25, 2009
Here is a accurate list of what you will need. Conversions are also easier when you have a manual motor.
http://www.hondaclub.com/forum/artic...part-list.html
Old Mar 1, 2009
jimmezero's Avatar
yea thanks dude
Old Mar 11, 2009
jimmezero's Avatar
hey on the clutch pedal. do i have to plug two wires to the two sensers on top of the clutch pedal? any info will help
Old Mar 13, 2009
http://hondaswap.com/civic-del-sol-e...version-72243/
Old Mar 13, 2009
jimmezero's Avatar
thanks dude and i have another ? to ask. my old motor has a black and a green wire on the powersteering switch and my new motor has just the black wire and they cut the plug off of it. so i want to know wat do i do about this?
Rinzlor
Apr 24, 2015 10:33 AM
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Killagi
Apr 12, 2015 10:42 AM
