Brake Fluid Change Maintenance
Old Dec 19, 2008
ardello11's Avatar
ardello11 is an unknown quantity at this point
Standard maintenace schedule includes brake fluid change at 50K. Never changed fluid on previous cars unless I was replacing pads or rotors as part of brake job. Cannot argue that changing brake fluid doesn't hurt...but is it really necessary or should it be optional?
Old Dec 19, 2008
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
Re: Brake Fluid Change Maintenance
it not mandatory to change your brake fluid...hell i skipped mine too lol
Old Dec 19, 2008
brake fluid is supposed to be changed every 3 yrs, not dependent on mileage. this is to prevent corrosion of the braking system and costly repairs down the road due to the old fluid absorbing water and forming contaminants. no you never have to change it, but you will realize later why you SHOULD change it.
Old Jan 2, 2009
natey57's Avatar
natey57 is an unknown quantity at this point
^ +1
Old Jan 3, 2009
sl33pyriceboi's Avatar
^gearbox is so smart.
Old Jan 3, 2009
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
Well, with that said, I'm gonna get it flushed, lol.
Old Jan 3, 2009
d_lo77's Avatar
d_lo77 is an unknown quantity at this point
i would do it when the fliud starts to get dark and not clear. its best to do it at the recommended interval but i would wait a couple more years instead. it takes a VERY LONG time for the brake system to start corroding itself even in canadian weather without rustproofing. i would change the fluid once or twice during the entire the life of the car
Old Jan 3, 2009
true you can always tell by looking at the fluid. i do mine at 3 yrs just for peace of mind, the fluid still looked fine.
Old Jan 3, 2009
make a DIY!
btw, is there a proper way to do it?
ive always just bleeded my brake lines untill the reservor almost out and pour some mroe brake fluid in. i usually use up a bottle or two.
Old Jan 3, 2009
nedct's Avatar
nedct is an unknown quantity at this point
i need a little help posting something..
c mon. don't laugh..
I cant figure out how to post . i started a new thread, some reason i dont think that was the right thing to do.
Old Jan 3, 2009
nedct's Avatar
94 honda civic 1.5
fan motor is not working.. car over heats...tested fan and it works. replaced relay, checked fuses. Car revs to almos 3 gs then cuts to 800 approx. also replaced t-stat before finding fan prob. overheats and floods reservoir
Old Jan 4, 2009
^make a thread noob o_O
hahaha jk. (but really, make ur own)
Old Jan 5, 2009
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
make a DIY!
The way I've always been told to do it is to start with the wheel farthest away from the resevoir and work your way closer. If you use a fluid that is a different color it makes it super easy to tell when the new fluid is in the lines. If you are in need of a flush, then they fluid you use to replace will be a different color anyway.
Pump the brake a few times and hold, release the bleeder valve on the caliper then retighten, pump the brake a few times (until firm) and repeat until you can see that the fuid coming out of the bleeder is the new fluid. All the while keeping a careful eye on the resevoir. Make sure the fluid level never goes below the min line. It's very helpful to have 3 people for a flush, unless you have a kit that sucks the fluid out.
Old Jan 5, 2009
ur suppose to do it the way ur ABS is set up.
and usually after a year, ur fluid turns pretty black...its deffinatly noticeable from the newer fluid
Old Jan 5, 2009
wow mine has stayed like new even after 3 yrs, almost transparent with lil yellow.
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
mrohitredd
May 28, 2015 10:03 AM
bsmiley
Apr 27, 2015 01:27 PM
civicdude
Brakes
Nov 21, 2001 08:00 PM
