stock radio question. please help!
Re: stock radio question. please help!
there should be a card where the cars manual should be, if not take out the stock deck and there should be a little sticker on there with the numbers.
thats how it is for my 02 coupe, so it should be the same or similar?
Here's a
of mine... this was from another thread
Dude.... here's a FREE solution. call honda support... the national number. Tell them your serial number on the car. They will most likely tell you aren't the registered owner of the car. They will have you fax a copy of your driver's license and the registration of the car to prove you are the owner. Fax it to the number they give you, then call them. After you are the proud new REGISTERED owner of the car, they will be more than happy to give you the radio code.
I tried to get the dealership to do this for me and they wanted a hundred bucks to do it. Do it yourself for free, won't take 30 minutes even. Good luck buddy.
of mine... this was from another threadDude.... here's a FREE solution. call honda support... the national number. Tell them your serial number on the car. They will most likely tell you aren't the registered owner of the car. They will have you fax a copy of your driver's license and the registration of the car to prove you are the owner. Fax it to the number they give you, then call them. After you are the proud new REGISTERED owner of the car, they will be more than happy to give you the radio code.
BootyDo
Jul 7, 2015 06:06 AM
mapdog
Jun 22, 2015 05:36 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
