Help Please, building motor ( R18 )
Old Dec 12, 2008
Shroomy07cex's Avatar
Shroomy07cex is an unknown quantity at this point
Exclamation Help Please, building motor ( R18 )
First off can sombody give me an estimation of how much i could pull a motor out of a salvage yard for?
secon, im going to get the head ported and polished, new valve springs, new rods, and stronger pistons.
Anything else i need to do to get ready for high boost?
Then i want to get the weapon-R intake manifold to replace the plastic stock one.
I want to be able to push 20 psi.
Old Dec 12, 2008
Clean 03's Avatar
Clean 03 will become famous soon enough
Re: Help Please, building motor
What motor are you even talking about?
Old Dec 12, 2008
R18 it's from an 07 civic ex. Sorry i didnt specify
Old Dec 13, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
Re: Help Please, building motor ( R18 )
good luck with that one! not sure what you can do with that one.. as its got an integrated exhaust port, which eliminates a header, so no real gains there.. unless you make a test pipe or are able to bolt a turbo directly to the head, theres really nothing you can do with that engine
Old Dec 13, 2008
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Yeah, I don't think a turbo manifold even exists for that motor because of the integrated exhaust manifold. You'd be much better off swapping in a k20, although it will be very expensive. You could run decent boost levels on a stock k20 though, so you can save on the build.
Old Dec 13, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
they already have a turbo kit out for the R18 guys. lol
Old Dec 13, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
dont use that motor...honda has a problem with the block leaking coolant..basically a porus block...i have changed 3 engins already at work (honda) because they were leaking...if you make this thing work even harder then it has to its sure to fail...just go with the k20 way way better motor even just in stock form. the r18 is just a grocery getter
Old Dec 13, 2008
02civicg5's Avatar
02civicg5 will become famous soon enough
dis is funny.. lol grocery getter!!
Old Dec 13, 2008
WannaBFast's Avatar
why do a swap.. its cheaper to trade up.. LOL
Old Dec 13, 2008
bakertime's Avatar
My bad, didn't know one existed!
Old Dec 13, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
check out 8thgencivic.com. and they probably will be more helpful.
cizsak
Jul 21, 2015 03:39 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
