white exhaust smoke
Old Oct 16, 2008
ekturbo's Avatar
ekturbo is an unknown quantity at this point
white exhaust smoke
Hey im new to this forum but need help bad. I have a jdm d15b with 35000ish miles and greddy turbo kit. I recently blew my head gasket i believe. so i replaced it and the smoke is alot better not nearly as much at all. There is still a little but not till it starts warming up. I also replaced the pcv valve nothing has completely cleared it up. All help will be appreciated but i need it fixed!
Old Oct 16, 2008
Re: white exhaust smoke
did you check the head for warpage and proper compression when it was taken off? obviously coolant is still being burned. could try replacing the radiator cap as well.
Old Oct 16, 2008
ekturbo's Avatar
Thanks for quick reply. no i didnt have those things checked and knew it could come back to bite me. Im getting all that done this weekend i decided to take it back off and have it checked and mill it if needed. What can a bad radiator cap do? Just curious.
Old Oct 16, 2008
hwt101's Avatar
hwt101 is an unknown quantity at this point
you should almost always have the head resurfaced when you do a head gasket to ensure a proper seal. And a bad radiator cap can cause your coolant to boil faster due to a loss of pressure, it can also cause the coolant to not flow properly due to the loss of pressure, oh and it could spray down the engine bay with coolant as well
Old Oct 16, 2008
ekturbo's Avatar
ok im going to buy a radiater cap cause the one i have is all coroded. I just noticed too that my lower pcv valve hose to the breather on the crankkcase is disconnected. Not sure if that could be a cause but just leetin ya know incase you have input about that.
Old Oct 17, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
You'll also get white smoke with turbo coking right? Do you have a turbo timer and such? I donno. I had a smoke problem with one of my first cars, and it turned out that oil was leaking into the spark plug hole.
Old Oct 17, 2008
manahoonie's Avatar
burning oil too... happened once while i had my Volvo...
also, whenever one of the mechs does an oil change on an RX-8, he always puts too much in, so he has to burn some off, fills the entire garage area with white smoke
Old Oct 17, 2008
ekturbo's Avatar
im pretty sure it is bad turbo seal. I found oil in intercooler piping and there is feel-able shaft play. I took it for a drive and couldn't see any smoke but it also wouldn't boost. I could hear the turbo but wouldn't go past 0 boost This would cause smoke due to oil leaking into exhaust and then being burned?
Old Oct 17, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
bad seals or not, you should be able to build at least a little boost. make sure your turbo isn't shot and pushing boost pressure into the oiling system. that would be very bad for your whip
Old Oct 17, 2008
02civicg5's Avatar
02civicg5 will become famous soon enough
white smoke from your exhaust means your running rich on the turbo bro
Old Oct 19, 2008
ekturbo's Avatar
it does build boost i had a intercooler pipe loose. drives fine just little smoke. I did also find silver reflection in thye oil inside intercooler pipe. that means grinding bearings or fin against the housing? im getting a new turbo and see if that fixes it unless there is something else i should check first. Thanks a lot.
Old Oct 19, 2008
ekturbo's Avatar
also what is a good upgrade from the 15g that will fit the greddy d series kit turbo manifold? thanks
Old Oct 19, 2008
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
white smoke is not the cause of running rich. it means u have one of these:
-crack in head
-burning coolant/water
-bad seals
black is the cause of running rich or a blown turbo.
Old Oct 19, 2008
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
-crack in head
-bad seals
bingo he is absolutely correct
alinaray
18
Aug 24, 2015 01:04 PM
WaryDriver
Aug 22, 2015 06:50 PM
USCGBM
Aug 12, 2015 04:22 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
