Trunk mesurments
Trunk mesurments
I'm building a custom box for two 12s and two 10s. and i need to know the dimentions of a 2004 civic coupe, special edition..(canadian version)
anyone that has a tape measure that can do it would be amamzing...im at school and i got nothing to measure with.
Re: Trunk mesurments
there ARE some diys with it i believe
and which dimensions do you want? point to point...the widest part, the narrow part, where?
i need like lengths of each outter line of the trunk...i tried to type a picture of it but it messed up....like the primeter of the trunk floor. and the height like floor to the where the trunk bars re and the 6x9s and so on..jsut so i wont make it too small or too big..i want a nice snug fit in there..
sorry im not great at typing these things out..id be fine if i had my own measuing tape ahah
well it's also how you want your subs positioned...two facing forward, two facing back, one on each side by the back....
this should help get you started....
https://www.civicforums.com/forums/1...ml#post3537858
(rep me?
(rep me?
) Last edited by manahoonie; Oct 16, 2008 at 08:29 PM.
dude first off 2 10s and 2 12s are gonna sound like ****. dont be ghetto. second of all, if you build a box thats a snug fit, it wont fit in the trunk opening. i have 4 jl 8w7's that require a big *** box and i built it to fit perfect and it wouldnt even fit in the trunk opening. i had to start over and build one that will fit the opening rather than the trunk behind the seat. quit being a noob and buy a box or go learn what the hell youre doing. boxes have to be made per the subs requirements, not whatever looks pretty in the back of your ghetto civic.
/\/\ building one that does fit snug i believe IS possible, i think i've seen it done before a couple times, just has a normal type of box in there, and twl small pieces on the outside edges to fill in where the cuurve of the wheel well is.
ALSO, it would most likely need to be installed IN the trunk, not outside, and then stuck in
u could do it with filler panels but not a box that fits snug. it wont fit. and 2 12s with that much air space would sound like **** if you built a box that big. he needs to do some reading a measuring before he builds anything and seriously reconsider 2 12s and 2 10s
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
Skunkone
Sep 24, 2015 04:38 PM
