headlights dont work but one high beam does???
Subscribe
Sep 18, 2008
my light bulbs are good and the fuses are good. the dim/parking lights and blinkers work and the headlights will not beam at all and when u turn the high beams on only the passenger side light works....nobody knows what to do....can anybody help?
Sep 18, 2008
Re: headlights dont work but one high beam does???
check if your relay is clicking under the hood when you turn your lights on and off
Sep 19, 2008
If they are aftermarket I want you to check for grounding. My bet is some sort of lose connection.
Sep 19, 2008
yup its always a grounding issue in most case. there was a recall for 01-02 civics where a wire in the switch would burn and cause lo beam not to work.
Subscribe
