HID LIGHTS
Old Apr 3, 2002
EZ's Avatar
EZ
EZ is an unknown quantity at this point
HID LIGHTS
I am about to purchase the Phillips HID conversion for my 2001 EX Civic, My question to anyone that has them are they hard to install and are they worth the money ?
Old Apr 3, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
mine were 549.95 , worth the money, and easy as shizzzzzz to install
Old Apr 3, 2002
EZ's Avatar
EZ
Where and what kind did you get and is there any hints on installation? Are they really bright ????
Old Apr 3, 2002
very bright, a distinct beam. i got the purple bulbs and everybody loves them. i got the philips HID conversion (H4)
installing is easy. the wiring harness is made to fit OEM stock lights and the instructions make it easy...youll ahve no problem!
Old Apr 3, 2002
choiboy19's Avatar
choiboy19 is an unknown quantity at this point
what happens if you hit the high beam switch with an HID conversion???
Old Apr 3, 2002
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Well if you go to GROUP BUY...there is deal on for the HELLA/PHILLIPS HID kit...for like $560 or something...for dual beam...hahaha for the H4...and single beam is like $100 cheaper...I would give you the http:// but you have to be a member so sign up for free...and go check it out....I think the HID high beam would be killer...but mabey the high beam is only as strong as 2k2civicballers lowbeam...who know...but go check it out......
Old Apr 3, 2002
klam's Avatar
klam is an unknown quantity at this point
I've heard that because of our headlight housing design (designed for halogen bulbs), even retrofit HID kits create too much oncoming glare for other motorists?
Old Apr 3, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
i got my Philips HID for $385.95
if u r a member of GroupBuyCenter.com then u should be able to get lots good stuff for cheap
Old Apr 3, 2002
Dave's Avatar
Dave is an unknown quantity at this point
Very easy to install, just make sure you make a shield to block the light from hitting the high beam reflector if it doesn't already come with one.
Rogelio Rey
May 24, 2015 08:30 PM
werdnahall
May 17, 2015 11:37 AM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
WhosYoDadday85
Nov 11, 2001 05:41 PM
