Fix Alternator/Engine Noise!!
Old 04-22-2008
tuan25000's Avatar
tuan25000 is an unknown quantity at this point
hey guys... im sure alot of you have this problem with the whining noise coming from ur speakers. I just fixed mine after having the noise for over a year. i took it to like every shop and none of them could figure out what exactly was causing it. apparently, alot of the pioneer decks have issues with the internal ground which is causing the noises.
ok so heres what i did... it was really simple and it completely got rid of the noises. I took the deck out and i grounded the rca wires by wrapping wires around it... then i bolted it down to a screw... and that was pretty much it lol. i have included pics below so you get the idea. if you are having this problem and you've tried everything, give this a try and let me know!
tuan25000 is offline
Old 04-22-2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: Fix Alternator/Engine Noise!!
Yes, known pioneer issue. Recommended fix (from Pio) is to add a lineout converter off the speaker wires.
christmaspie is offline
Bradel26
05-30-2015 10:24 AM
RyanCoult
05-29-2015 09:50 PM
bo_red
Transmission
05-03-2015 09:14 PM
123CiViC
01-19-2002 08:52 PM
silvervtec01
12-09-2001 08:50 PM
Quick Reply: Fix Alternator/Engine Noise!!
