BOILER!! :) assembling new block this weekend. got few questions
Old Apr 22, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
yooo well im about to assemble my new block this weekend and i was wondering if there are any pointers you engine builders could enlighten me with .
im confused on where to apply assembly lube when i put the pistons in and on the bearing surfaces. do i put the lube on the back side of the bearing or on the part where the bearing contacts with the journal? also is it necessary for me to get engine break in oil? because everything i am putting in the block is pretty much new. last question. how do i pre-lubricate [prime?] my oiling system before the initial startup of the car so that everything is lubed before i start the car? thanks for any help. will rep you if i can
Old Apr 22, 2008
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
Re: assembling new block this weekend. got few questions
where the bearing contacts the journal
Old Apr 22, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
change your thread title to ask for boiler!
Old Apr 22, 2008
Re: BOILER!! :) assembling new block this weekend. got few questions
^^ done. lol. good idea. bumppp for any help!
Old Apr 22, 2008
Envy's Avatar
Diamond Member
hahahahaha nice! i really dunno much about this, but depending on what your building this motor for, maybe youd wanna use synthetic from the start, instead of break in then conventional?
Old Apr 22, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
1. - Get a Honda Service Manual (this will save your life!)
2. - Lube is your friend, lube everything that moves ( This is you priming your engine for cold start )
3. - Just use regular motor oil....wait at least until 10-15k before synthetic...allow the engine to break in alittle before you make it super slick
4. - There are alot of debates on how an engine should be broke in....some say build it, dyno it, & beat it up....some say baby it for at least 3-5k....some say just drive it normal....I would drive it normal until 3k & then beat it up.....let the parts get familiar first!
****you can prime you're oil system by turning the oil pump manually (timing belt drives oil pump) I don't know if you will be able to turn it fast enough, however. Old V8 guys use an adaptor & power drill to prime alot of old v8's***
Old Apr 22, 2008
TRIZ's Avatar
I dont have time to read through this because I have to run, but this should help you out.
http://www.team-integra.net/sections...ArticleID=1220
Old Apr 22, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
I wrote a huge thread, search for it.
Assembly lube goes on the surfaces that contact the crank, not the back side against the block. Same for rod bearings.... the side that contacts the crank.
Get a honda service manual, follow all the torque orders.
Break the motor in on conventional oil. Prime the oil system by pulling the PGM EFI fuse under the hood then crank the car a couple times for a couple seconds. The idiot light on the dash will go off when its got pressure, but if you used good assembly lube, that will keep you good for the 2 seconds until the motor pressurizes itself fully. Leave the radiator open, you'll have to fill it as you go, but make sure its as full as possible before you start it. After 15 minutes, do an oil change. Then you can drive the car.
All this is in my huge thread, its in the 7th gen FI section.
Old Apr 22, 2008
thanks you everyone for your help! just what i needed very nice link triz thanks.. doesnt seem that difficult ... i had a few more questions though.
should i put the ARP assembly lube on the rod bolts? [not the threaded part] because i pushed them ARP rod bolts in already without the lube.
would my autozone torque wrench do fine for torquing everything down? maybe its not accurate enough or what not?
thanks for all the help guys.
Old Apr 22, 2008
TRIZ's Avatar
For the lazy, here is a quick link to the thread boiler is talking about:
https://www.civicforums.com/forums/7...000-miles.html
Old Apr 22, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
put the arp assembly lube on the threads it will give you a better more accurate torque reading lubricate everything and whatever you do don't use synthetic oil with the new motor until it gets really broken in. Synthetic does not contain bits of minerals that help break-in the motor that you would find in regular motor oil. all the motors that use synthetic straight off the show room floor are pre broken in at the factory.
Old Apr 23, 2008
^^werd. thanks man. i would rep but i cant
Old Apr 23, 2008
andyman97's Avatar
Turbo Guru
I wouldn't use assembly "lube" on the bearings at all. The Honda service manual recommends coating them with clean engine oil and that's exactly what I did.
Old Apr 23, 2008
any word on the ok for using an autozone torque wrench? maybe the torque readings are off?
alright thanks andy! +1 please rep back!
Old Apr 23, 2008
andyman97's Avatar
Turbo Guru
I'd use a craftsman....
Old Apr 23, 2008
SpeedFreak's Avatar
SpeedFreak is an unknown quantity at this point
Its definately worth buying a craftsman, the no name wrenches may not be calibrated properly and are cheaply made. Before assembling anything make sure you use an air gun to blow everything out, dont want any metal shaving or other misc. things that creap into the block. Make sure that you apply some oil to the cylinder walls before installing the pistons, put some oil on the piston pins when they are in, also oil your oil pump and rear main seals.
Old Apr 23, 2008
SpeedFreak's Avatar
O ya as far as assembly lube, I agree with Andy conventional motor oil is fine.
Old Apr 24, 2008
^^ thanks speedfreak +1 rep for youuu! rep back please
SORRY. i think this is the last question lol. well i just got back my motor and head from the machine shop.. there is rust in the cylinder walls now. how do i come onto cleaning them? i tried wd40 and i ran out of brake cleaner. brake cleaner kills rust i think yah?
thana
Jun 15, 2020 07:05 PM
hokiedad4
Apr 30, 2015 07:18 AM
superstanko
Apr 28, 2015 04:38 AM
viper775
Dec 9, 2001 10:52 PM
