ok timing belt slipped and crashed my exhaust valves...****.where should i go for a good inexpensive valvetrain package?any ideas would be greatly appreciated.
Aftermarket valves,springs, & retainers are probably very close to stock prices. It may be worth it!
You'll also have to take the cylinder head off so I would also do....timing belt,water pump, crank seal, cam seal.....
Stock valves are substantially cheaper than aftermarkets. I think stockers are $7 a pop for exhaust valves.
If all you need is a couple valves, just replace the bent ones, but make sure everything else is kosher first.
