filtermag magnets? harmful at all?
Old Apr 15, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i was researching on these magnets called filtermags. its really just a big strong magnet you stick in your diff/tranny/oil pan to catch fine oil particles that could harm your engine and that your oil filter can completely miss, looks pretty neat..
http://www.filtermag.com/
i was wondering if this would be harmful to the engine somehow? i will be using the transmission magnet with 25lbs of pulling force and putting it inside my oil pan under the oil pick up. can this harm my engine in any way? only way i thought it would be harmful is if it somehow caught onto the crank or something [ i will put it under the baffle]
sorry if this sounds so noob lol.
Old Apr 15, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Re: filtermag magnets? harmful at all?
Honestly, I've got a big red flag going up when you're talking about putting something in your oil pan, even if it is a magnet. That just doesn't sound like a good idea, IMO. If it were me, I would make sure it was necessary. Like, next time you change your oil, run it through a coffee filter, or even a clean t-shirt and see if you have any metal particles. I'd just be more than a little leery about putting something in my oil pan.
Another idea is a magnetic drain plug, I know those have given good results.
Old Apr 15, 2008
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
I agree with the drain plug. You don't have to worry about it getting knocked loose and if it does you have a lot bigger problems than metal particles in your oil.
Old Apr 15, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Some cars have magnets built in don't they? Maybe not in the oil pan, but I've seen them in transmission pans.
Old Apr 15, 2008
PitchBlack's Avatar
yeah they do but the key part of that is "built in"
Old Apr 15, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
my magnetic drain plug works great for me
Old Apr 15, 2008
hmmm what if i put it outside the oil pan? the filtermag tranny magnets go outside the transmission casing and the metal still sticks to the magnet through the tranny case. would this be a better alternative? i think so.
Old Apr 15, 2008
Unevolved's Avatar
It might, yeah. But again, you've got to wonder if the cons outweigh the pros here. I'd be a little leery about magnetizing my transmission case with a powerful magnet. Again, I'd make sure you need it first. If you've really got that many metal shavings in your oil, I'd be dealing with whatever's causing them. Treat the problem, not the symptoms.
Old Apr 15, 2008
im currently rebuilding an entirely new motor and i want it to last. i think i will just put it on the outside of my oil pan..
Old Apr 15, 2008
pheaton's Avatar
Meh, go with the plug.
Old Apr 15, 2008
ProjectMayhemR's Avatar
the best kind of lovin is from the oven!
ProjectMayhemR will become famous soon enough
alot of drain bolts are magnetic, plus good oil filters catch particles and crap like that. I happy with my wix filter. putting a magnet on it seems unecessary. dont waste your money it looks like a scam
Old Apr 15, 2008
cinaibur's Avatar
i've heard you can get oil filters with a magnet it them. but i've never actually seen one
Old Apr 15, 2008
scam? rofl. i just decided to get it and put it outside the oil pan and not inside. the drain plugs are pretty weak i dont think it will do that great of a job getting the gunk out. my buddy has a drain plug and it couldnt even hold a rachet. the filter mag can hold like 50lbs weights. sounds cool. lol
Old Apr 15, 2008
DsevenEm2's Avatar
This is Myspace
do you honestly think you're going to catch anything in your oil pan or transmission that weighs the same as a ratchet and still have it functioning? seriously.
Its not for gunk.. its for metal shavings from wear/tear peices. gunk isnt magnetic.
All outboard lower units (boat motors) have magnetic drain plugs.. they're good tools to identify whats going on inside, so i'd recommend one for the oil pan.. but that thing just seems unnecessary.. 50 lbs.. come on..for WHAT?
Old Apr 15, 2008
my tranny drain plug was quite good at catching metal shavings. i personally think the drain plug and filter is good enough.
Old Apr 15, 2008
Unevolved's Avatar
The Pilot has a magnetic tranny plug, for what it's worth.
In my car, I'd be fine with a filter and magnetic plug, at most.
Old Apr 15, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
if you have 50lbs of shavings floating around in your oil pan, youll need more than a magnet before you lose your pan on the road.
Old Apr 15, 2008
^^ lmao it just seems to be more effective i guess! lol.
SolidHollow
15
Sep 13, 2015 11:18 AM
Yakkolio
May 8, 2002 12:58 AM
hose2k1
Apr 17, 2002 07:09 PM
02Si
Bolt-on Engine Performance
Jan 7, 2002 11:35 PM
