need some head torque specifications
Old Mar 23, 2008
01candycivic's Avatar
01candycivic is a jewel in the rough01candycivic is a jewel in the rough01candycivic is a jewel in the rough
so i am looking through my haynes manual and it give's me some head spec but i am not shure about them
for the head, it has three step's
step 1. 14lbs
step 2. 36lbs
step 3. 49lbs
it also told me to soke my bolts in oil so i did, now i have oil comming out from under the head. is this right or do i have to have more the then 49lbs on my head bolts. that would explan why there is oil comming out of the head.
i also need the s torque specs for the cam gear, rocker arms and everything else. i need some help. also if anyone knows where a engine wiring harness.i need two PIECES, 1 is ont the trans its a auto and the other is on the condencer.
i need the female end to on the trans here a pic
Old Mar 23, 2008
Re: need some head torque specifications
this it the other its the air conditioning pressure switch
Old Mar 23, 2008
speedfoos's Avatar
That's the right torque procedure for the head bolts. My guess is that you put too much oil on the bolts and that's why some of it squirted out. It "should" be fine though, as long as you don't plan on boosting it.
As far as your other torque specs, the cam bolt has a torque spec, but I always use the universal spec of "about that ****in' tight" on it and have never had any issues, Use a little Loctite if you're worried.
Rocker arm torque specs are in the book at the beginning of the chapter that shows you how to do the valve lash adjustment, 2A if I remember correctly. Also I'm pretty sure the torque spec on them is 19 ft/lbs , but my Haynes is in the garage and it's snowing out right now.
Why did you mess with the rocker arms? Your Haynes manual should have the torque specs for everything in it, they are at the beginning of each chapter. What else did you remove?
Old Mar 23, 2008
i took the head down to get resurfaced. would have been more if thay had to remove it so i just went ahaed and did it.. this is one big pain in the ***. i was gonna do a full bottom end and a p&p on the head but i just went ahead and put everything back. i made shure it was tdc on the bottom and on the to. did i need to rotate the camgear befor i put the belt on or am i gonna be ok. i should have everything put back together today sometime.... im trying to think about what eles i can ask. oh i think i fixed the harness on the trans, i will find out today if it worked.i hope evert thing turns out ok i am taking mar car to panama city this weekend
Old Mar 23, 2008
speedfoos's Avatar
I'm not sure what you mean by do you have to rotate the camgear before putting in back on. If was at TDC when you took it off, and you marked the belt and the gear so they have the exact same position as when you took it off and go back on the same teeth, then you should be fine.
Old Mar 23, 2008
i cahanged the warter pump and all the belts so i could not mark it
Old Mar 23, 2008
army12bc's Avatar
army12bc will become famous soon enough
http://www.xproductionz.com/servicem.../Civic0105.zip
this is the honda ETM
Old Mar 23, 2008
im not sure why you soaked the bolts in oil. in fact they come pre-oiled in the bags already and you should not need to do anything to them. but if they were dry (aftermarket ones?) i wouldve just wiped them with oil so the threads are lubed.
Old Mar 23, 2008
ok so i just finished up putting on my headgasket and ill sht **** that goes with it.... and i have a kinda big problem i ha a big *** bolt and i have no idea where it goes. its killing me here in my hand is the bolt
and the other parts i put on
Old Mar 24, 2008
anyone hahe a idea about this
Old Mar 24, 2008
speedfoos's Avatar
Does it have a 12 or 14mm cap on it?
Old Mar 24, 2008
its a 12
Old Mar 24, 2008
speedfoos's Avatar
Did you pull the waterneck off? Those take 12mm bolts.
Umm......it's not from the PS or Alternator cuz the mounting brackets are 14s and it's the 12mms on those are nuts..... Water pump is 10mm....
What about the timing belt tensioner? That takes 12mm bolts.
Clutch slave 12mm bolts are shorter than that and you shouldn't have taken those off.....some of the IM bolts are 12mm, did you take any of those off?
You got all the rocker assembly bolts back on?
Old Mar 24, 2008
Rufus's Avatar
I never keep bolts organized anymore. I put them in a pile and I always know what I need from that pile as I reassemble stuff. lol
Old Mar 24, 2008
speedfoos's Avatar
I'm the same way Rufus. There only 3 choices anyway, 10, 12 and 14mm and they have their corresponding marks on the "O-****!" meter when they are left over. 12mm is about a 3.5 or 4 since the dial goes to 10.
Old Mar 24, 2008
yeah i keep going over where it came from and i remember putting on all the bolts..... should i start it anyway....
Old Mar 24, 2008
if it bolws up im just gonna burn it
Old Mar 24, 2008
i got good news and bad... the good i have it put back together.... the BAD i still cant find out where the fuc@ing bolt goes, and i have gas comming out of the injector next to the cam gear...oh and it will not start, so does anyone want to buy a civic
Old Mar 24, 2008
im tempted to say bottom of the intake mani, you can reach it from the top with a short socket wrench. same happened after my head swap. and it caused a rattle sound when they werent bolted back in.
if it wont start, try making sure all the vacuum lines and connectors are plugged back in including ones around the timing area like tdc, cpk, crank, cam etc.
Old Mar 25, 2008
ill look again when i wake up i just got off work its 5:39 am. if anything i am just gonna rip everything back off and do it again. should not be hard. it looks like there might be some red **** on the threds. i rember putting the intake on wheen the head was off the car so i dont think that was the bolt. but u might be right ill check it out.... good looking out gearbox.
Old Mar 25, 2008
nope i have al the damn bolts in it. i had to order new o-rings for the ijectors the orange one that goes into the M/F. and i think i might need a new injector so if anyone has a stock one laying around give me a price or can i just put rsx in. ill get a pic up so you can see it. my parts will get in thur. so keep you fingers crossed
Old Mar 27, 2008
ok i am going to burn this damn car. i have everything back together i still cant find where the bolt goes. i started it up at frist it idoled a little high around 15 hundred rpms and went back down to just under 10. so i took it for a ride i was doing fine intil it was trying to die on me. i was down the street from my house and so i pushed it to try to get back home. well that did not happen cause it died on me. it would start and then die again, i coulsd hear my ecu shutting off befoe it died.. after 4 times of it dieing on me i just held my foot on the damn gas and said **** it... it started and i was off... what the hell is causing this? i think i am going to rip it back down and redo everything,,,,,,,
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
thana
Jun 15, 2020 07:05 PM
Jun 2, 2015 11:54 AM
Grey
17
Feb 21, 2004 06:21 PM
Grey
16
Jan 27, 2002 11:34 PM
