hiding neons??/
Old Mar 27, 2002
blackasnight2001's Avatar
blackasnight2001 is an unknown quantity at this point
hiding neons??/
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] i got some blue neons for my car( i know [IMG]i/expressions/face-icon-small-puke.gif[/IMG], oh well ) and i want to mount them under the 2 front seats, but the carpet isn't good for using the sticky stuff, but
is there a way to put them there without drilling and if so whats the easiest way...(they are both 12")
Old Mar 27, 2002
bambuski's Avatar
bambuski is an unknown quantity at this point
I have them under my seat with 12" in the front and 12" in the back on both sides and just cut little holes in the carpet and used tie-raps for hold them down.
Old Mar 27, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
why cut holes in the carpet, when you could strap them to the underside of the seats?
Old Mar 27, 2002
bambuski's Avatar
I ran the wires for the neons under the carpet. So the holes were already there from the wiring. and instead of have the wires going up the underside of the seat and have the chance of hitting them i used tied them to the carpet.
Old Mar 27, 2002
why didn't you run them down the center console? i'm sure it would have been easier.
Old Mar 27, 2002
chance of hitting them? i've had them there for ages.. and many people have followed both toastyghosty and my lead and done the same.
i'm sure you way is more than handy, but the way i did it, nothing needs to me cut or mangled.. i'm sure alot of people would rather not cut holes in their cars.
Old Mar 27, 2002
bambuski's Avatar
probably would of been. but i usually slip my CD case under my seat when i park my car. In my friends he wired them to under the seat and kept hitting the wire with his CD case. So i just did it the harder way to avoid that.
Old Mar 27, 2002
mm.. he must've done a shotty job.. i also thorw my cd case under my seat and i've never had a problem with the way i have it set up..
Old Mar 27, 2002
i did go wire it through the console, but where should i mount the lights, under the seat or against the carpet, and in a safe way???
Old Mar 27, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I've had mine under there with 3m double sided tape for almost 8 months now and they have never came undone.
Old Mar 27, 2002
Toad's Avatar
Toad is an unknown quantity at this point
two words.. duct tape... its the best stuff it the world.. i just taped mine underneath my seats.. look hella awesome
Old Mar 27, 2002
<< two words.. duct tape... its the best stuff it the world.. i just taped mine underneath my seats.. look hella awesome >>
the glow off of the tubes might look hella awesome.. lol.. but i'm sure as hell the install looks pretty bad.. haha.. duct tape? ah well.. to each their own.
Old Mar 27, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
i don't know what type of tubes you have but i have the fat ones, not the thin one's
so i mounted them to the carpet. On the passenger side the neon gets in the way of the bar that slides the seat foward. i'm still trying to relocate them some where else to get better use of the glow
and you should run the wire under the center console.
that's what i did.
good luck
o.. and i have (2) 10's in the front and 15" in the trunk
Old Mar 27, 2002
i think the majority of people have the regular sized ones.. which are the ones you refer to as 'fat'.
Old Mar 28, 2002
[IMG]i/expressions/face-icon-small-smile.gif[/IMG] well this story ended happy, i took the advice to use duct tape and now they are both under the seats and look so f'n awesome, blue light covers the whole floor front and back
thanx guys
Old Mar 28, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
i have 2- 20" sound activated strobes under the feet of the passenger and driver's side in my coupe. Theres always the chance people will kick it when they sit in your seat but i just put them there just cause it looks better and the effect of the color is much better. Also i was too lazy to wire the wires under the carpet so i just drilled into the panels that are under there and screwed them into the panels and put them back in. If anyone wants to see...come down to san dimas =P haha. That also allows me to get the larger strobes instead of workin with 12"s
Old Mar 29, 2002
2k2tiff's Avatar
2k2tiff is an unknown quantity at this point
i want to put a couple neons under my seats, but i'm not sure how to wire them. i was thinking to mount them at an angle so they don't get in the way of the seat lever thingy, the drivers side doing \ and the passanger / what do you think? i was going to just get some velcro and wrap it around something under the seat.
btw, should i mount them to the seat itself so it moves foward and backward, or to the frame piece?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Jeffdp
Jun 18, 2015 06:18 PM
viper775
Mar 5, 2002 04:44 AM
SLeePeR012
Mar 2, 2002 11:00 PM
Toad
Feb 27, 2002 03:47 PM
