Man, i dont like the underside of my car!
Old May 11, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Angry Man, i dont like the underside of my car!
Ok, just recently i decided to try to install my rotors and hawk pads, and i ran into a problem! this is not the first time i ran into a problem on the underside of my car either. Like there are 2 screws that keep the rotor on and the DIY sez use a impact screwdriver, cause of rust, and to let it soak in WD40 so thats what i did. But those blasted screws will not come off! and it sux! gah... time to take it somewhere to get it fixed and installed... crap
1st with my RSX sway bar install one of the endlinks wouldn't come off at all, now my stinkin rotors can be removed... man im just having all sorts of problems ... stinking underside! i wish i could get a entirely new underbody ya know...
Old May 11, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Re: Man, i dont like the underside of my car!
It wouldn't be any fun if it was easy.
Old May 11, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
i'm really **** about having a clean car, even the underside. haha.
get some stands for your car, jack it up and rest it on the stands and get under there with a wire brush and start going to town on the rust. then get some kind of cleaner like simple green or something stronger if its all super bad, spray it all down and let it soak, go to an automatic car wash that sprays under the body and let it do it's job. then go home, jack it back up, dry everything, get some rubber undercoating and apply appropriately. now you'll have an ace underbody. haha.
Old May 11, 2007
sl33pyriceboi's Avatar
are u using an IMPACT SCREW DRIVER to take the two screws out???
try getting some Screw loosener spray...you can get it at autozone...it is like WD40, but it actually eats away at the dust n rust n makes ur screw come out like butter =]
if it works, +1 for james wooooooooot
btw, make sure ur using a IMPACT SCREW DRIVER
Old May 11, 2007
tuner04civic's Avatar
spell check pwns you
i had the same issues but for other partsnow my best friend is a baker bar. for the screws just clean up rust put screwdriver in there snug and hammer it lightly to loosen the screw and get the snug fit with screwdriver
Old May 11, 2007
use pb blaster. wd40 is outdated and useless.
Old May 11, 2007
quoted for truth.
Old May 11, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
when we were installing my fogs, we put my car up on a lift to make it easier to run wires. I got really depressed when I realized there are anorexic girls with wider arms than my exhaust. Stock exhaust is seriously the diameter of 4 pencils taped together
Old May 11, 2007
DJ GEE's Avatar
DJ GEE is an unknown quantity at this point
If you can find BG penetrating fluid. They will loosen, then when you put them back on clean the screws and put some antisieze on them.
Old May 11, 2007
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
wtf does this have anything to do with the topic?
OP - if you stripped them, drill them out, that's what i had to do. yeah i know, it sucks, i had to do this too
Old May 11, 2007
LT2004ever's Avatar
See its not like rust just in the under body, its just mainly all the screws and bolts that i come across... i swear when i have in mind imma work on something, i swear that screw or bolt just seizes up and doesn't budge...
Yeah i am using a impact screwdriver, im positive. screw loosener spray...
thats exactly what i did, i cleaned up all the rust around it, then hammered lightly while turning...no movement.
umm... just wondering why u are talking about your exaust?? like just cause its on the underside of your car.... or... ummm
Old May 12, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
just keep hit the impact screw driver, make sure its turning the right way, you might be actually tightening it, mine came off with 4-5 good wacks, and i mean good with a rubber mallet
Old May 12, 2007
LT2004ever's Avatar
i'll try it again tomorrow morning with some PB blaster, or BG penetrate
Old May 12, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
wtf?
neways...gl i hope i dont encounter this when i finally install my rotors
Old May 12, 2007
speedfoos's Avatar
Yup, I can't tell you how many times I've tightened my screws down with my impact screwdriver. You don't have to turn it, the hammer blows will do that, its how its designed. Just carefully (so you don't mash your fingers) whack the crap out of it and they will come loose. I used my trusty Eastwing steel hammer.
Another tip. Don't put the screws back on when you put your new rotors on. They're irrelevant and only there to hold the rotors on during assembly at the plant. Your wheels and lugnuts hold the rotors on. Honda is one of the only manufacturers that have those screws. Most everyone else doesn't.
Old May 12, 2007
LT2004ever's Avatar
Thanks for the info man , but yeah the impact screwdriver was set to counter clockwise... then i read the DIY and thats what it said CCW then i also turned just add a little umph.. ya know...
Old May 12, 2007
Pwning Noobs 24/7
yea counterclockwise is good, just some FYI, the impact screwdriver is only meant to turn the screw a few millimeters, just so it loosens.
Old May 12, 2007
cato1978's Avatar
cato1978 is an unknown quantity at this point
Good call, i was about to tell him to leave those screws out once the rotor was free...but you beat me to it.... Here's some Rep....
Old May 12, 2007
chawski's Avatar
yup
Old May 12, 2007
TRIZ's Avatar
Seems like you have a lot of problems with things you cant get off..
Go to the gym and get man strength!!
Old May 12, 2007
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
LOOOOOOOOOOOOOOOOOOOOOOOOOOOL
Old May 12, 2007
i guess I misunderstood in the beginning. sorry for upsetting you BRAAAH.
Old May 12, 2007
skipbarber's Avatar
ive always used a dewalt electric impact gun with a #3 phillips bit and ive never had trouble getting those screws out.
Old May 13, 2007
LT2004ever's Avatar
ok guys i tried the and the two screws just wouldn't budge... i dont know what it is.... i swear this is really irking me... like i sprayed, waited a while, hammered, sprayed again, waited then hammered a again the me and my dad tried it, with no budge... GAH! and suggestions, other than drilling it out?
Old May 13, 2007
you need impact then. could be fused from heat
Old May 13, 2007
LT2004ever's Avatar
an impact wrench with a phillips #3 bit?
Old May 13, 2007
streetglower's Avatar
what did you expect, you bought a honda.
Old May 13, 2007
speedfoos's Avatar
^^^ WTF are you talking about?
Old May 13, 2007
its an econobox, why would it have a huge exhaust. buy g35 for that, or even the tiburon lol
Old May 13, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
travis, you need to grow some man ***** to take your car apart. dont try to turn the impact screwdriver while hammering. just hold it against the screw tightly and whack that bitch. when you hit the screwdriver, it turns inside by itself. ill give you a lesson at the meet in june on how to use tools.
