Motor Mounts or Engine Damper?
Old Apr 2, 2007
DDragon7's Avatar
Hey guys what do you think I should get?
I called a shop to order Ingalls Engine Damper ($238CDN) and they recommended to get stiffer motor mounts instead (about $50 CDN for 4). So which should I get? The thing is that I already order Ingalls damper at another shop no deposit tho.
Which will have less vibration and which will have smoother shifting?
I need to make a decision ASAP, if Im gonna cancel the other order.
Old Apr 2, 2007
soldierboi's Avatar
soldierboi will become famous soon enoughsoldierboi will become famous soon enough
Re: Motor Mounts or Engine Damper?
get stiffys man. you oem motor mounts are fine
Old Apr 2, 2007
DDragon7's Avatar
Dont forget the price factor, its cheaper to get engine mounts then the stiffy.
Old Apr 2, 2007
soldierboi's Avatar
hey man its really up to you bro. some people in here got the stiffy and they loved it. so just do what you can handle nah mean? lol
Old Apr 2, 2007
djmota's Avatar
if you concerned about vibration you should skip everything. the purpose for these things is to stiiffen the engine. the byproduct of that is vibration. IMO Do the inserts and just install the fronts (weakest mount) the vibes wont be so bad as doing the front and rear and its cheap as hell.
Old Apr 2, 2007
familycar's Avatar
i agree with Mota, inserts will do the job just fine and in fact will fix a broken or torn mount that is already there. i have the inserts on my TEG and they work great. they greatly reduce wheel hop and make shifting much smoother. but i feel the trq dampner will provide more as far as performance.
by the way i got my inserts for $40 off ebay shipped!!!
Old Apr 2, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
inserts.
Old Apr 2, 2007
DDragon7's Avatar
Hmm, I have been leaning towards the damper.
Old Apr 2, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
ive got a stiffy and energy suspension inserts. vibration isnt that bad and its only at idle. shifts are great and i have almost no wheel hop.
Old Apr 2, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
You have an 01 civic right? I'd suggest replacing atleast your front engine mount because with a d17, the front mount gets torn up really fast for some reason. Even with moderate driving.
Old Apr 2, 2007
dtjh1883's Avatar
dtjh1883 is an unknown quantity at this point
I just got the engine damper installed. It took a little longer than the usual install because I was using a strut tower bar. Long story short, I welded the ingals bracket to the strut tower bracket so that I could use both. Turned out really nice. I recommend it.
Old Apr 3, 2007
DDragon7's Avatar
What did you get first and did you notice farther improvements after you put you the second thing?
Old Apr 3, 2007
skipbarber's Avatar
im using the ESMM just in the front. the front motor mount on my 02 was completely destroyed, so i bought a new one and the ESMM and put them in. I must say that for the $20 i paid for them, it's been great. It vibrates a little when you go from a dead stop to moving, but after that it pretty much feels stock. we have so little engine room as it is, and the ESMM 100% out of the way. which is extremely beneficial to boosted people.
Old Apr 3, 2007
i put both on at the same time. i had 3 busted mounts including the hydrolic one. it made a huge difference. i dont mind the shakey idle because i dont idle that much.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mikemc422
Aug 9, 2018 05:41 PM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
