Suede Interior [Pictures Inside]
Old Mar 12, 2007
  #31
ArjoonKumar's Avatar
ArjoonKumar will become famous soon enough
i like how u have a carputer and roll-down windows
Old Mar 12, 2007
  #32
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Originally Posted by electric130
so open the door. that only takes 1 second!
Hence why I was trying to get the lock up so I could get the door open. You can't open a locked door. It was jammed down.
Old Mar 12, 2007
  #33
DeX's Avatar
DeX
Canadian, Eh!
I have another thread here already dealing with a power window conversion.
Old Mar 12, 2007
  #34
CecDogsVTEC's Avatar
Member
CecDogsVTEC is an unknown quantity at this point
Looks good!
Old Mar 13, 2007
  #35
phi5's Avatar
phi5 is an unknown quantity at this point
thanks for the infor dex.. i was thinking about adding extra foam for comfort..
Old Mar 13, 2007
  #36
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Very nicely done!
Old Mar 13, 2007
  #37
miklovo's Avatar
miklovo is an unknown quantity at this point
I was tryin to figure out the same thing, now it all makes sense....
whoa, that kinds puts a damper on your new suede doors huh.
"yah i'm done and it looks sick, wait now...why won't my door open?..ahh damnittttt!!!!"
j/k, we all learn the hard way I guess.
Old Apr 4, 2007
  #38
DeX's Avatar
DeX
Canadian, Eh!
Re: Suede Interior [Pictures Inside]
Got the shift boot done today.
Old Apr 5, 2007
  #39
electric130's Avatar
boot looks nice. car looks nice......and dirty! clean that sucker!
Old Nov 1, 2007
  #40
DeX's Avatar
DeX
Canadian, Eh!
The epoxy I previously had on my door was letting go on the drive through the USA but I left it thinking I'll fix it some other time. That was until my roommate pulled the handle right off the door about 2 months ago. And last night I finally got to work.
Here's the door after pulling the old suede off of it and sanding it with 60 grit sandpaper, then wiping the plastic shavings off.
Here's the old suede cutout laid on top of the new suede fabric. You can just use the old black piece, same thing. Make sure you lay the suede fabric down with the back facing you so your marker tracings will all be on the back of the fabric, not on the front. And make sure you have the template laid the right way, the first time I did it I ended up with 2 pieces for the same side.
Sprayed the back of the suede with glue, pressed it onto the door, and poked the edges into the cracks with a flathead screwdriver. Remember to cut out the suede larger than the piece that came off. It'll give you excess for placement and you can just hide the excess.
Hope Depot (Canada) carries this stuff which is perfect. I couldn't find it anywhere else, not even Home Depot USA. I had to get my dad to buy it and mail it to me, nobody carried it. But this is what it looks like on the shelf if you go looking for it.
And oddly enough, the actual product is on the back, it's a 2 stage epoxy in a plastic casing.
Mix the resin with the hardener at a 1:1 ratio with the stick and spread it onto the parts you want to stick together. In this case where the handle meets the door since you had to cut the plastic rivets in order to get it apart. Stupid Honda.
And that's it, it's sitting in the parking lot right now. I'm hoping it stays stuck this time and sets correctly. It looked like the shape of the plastic was pulling it away from the door though.
theteju
Aug 5, 2015 06:59 PM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
ballmich
Jul 9, 2015 11:59 AM
