Ran into a problem
Old Mar 6, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Ran into a problem
Ok so yesterday i began to put on my RSX rear sway bar and in the process i ran into a problem. The problem was with taking off the endlinks. ok i put in the hex key and held it tight while i turned the nut and like it stripped the inside where the hex key went....!!! sorry for the blurry pic
but yeah what should i do??? im just stuck, i dont wanna buy new endlinks, but i dont know how to get this bar off.
Old Mar 6, 2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
I can't remember exactly which side I did this on, but I ran across a similiar problem. I'm pretty sure the endlinks don't follow the whole lefty loosey righty tighty thing. So when you were trying to take it off you might have been tightening it instead of loosening it. If its not too badly "stripped" try going the other way with the wrench. I just might not know my directions, but pretty sure thats how they work. Good luck though.
Old Mar 6, 2007
LT2004ever's Avatar
yea it was backwards, but i got it moving a little, then the hex key just started totating in there and it stripped. BTW this is the drivers side. Also ihow can i go to the other end of it?? like its in this little closed housing that lets it freely rotate, just to the left of the red circle.
Old Mar 6, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Best bet is to replace the endlink(s). I think they're like $10-15 each from Honda/Acura.
To remove the sway bar, the nut loosens ccw. Hold the allen wrench still and turn the box wrench ccw, or pull them toward each other with the nut spinning ccw.
Did you use the right size allen wrench? I think it's a 5mm, or was that the shock/strut size. Hold on, quick search...yep 5mm it is.
Old Mar 6, 2007
Da1lyDr1ver's Avatar
you have to make sure you use a metric sized hex key or you will strip it out. and you'll have to spary lots of lube on the bolt itself so it penetrates the rust, etc.
you only option is to cut the endlink off and replace it, or i've even seen people use vice grips and be able to take off the endlink after it has been striped out.
Old Mar 6, 2007
account 22's Avatar
account 22 is an unknown quantity at this point
Removing the endlink bolts for me was a bitch, infact i think i did break them..
Cause i would try and loosen em (lefty loosey) and they would just continue to spin but no loosen, so in between the endlinke / swaybar / nut, i put some channel locks between the endlink/sway bar to stop it from spinning
Old Mar 6, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
+1 for vise grips. Get them on the silver washer looking thing. That way has worked all 3 times that mined stripped.
Old Mar 6, 2007
LT2004ever's Avatar
see thats what i did i had a 5mm hex key and i turned CCW! but the durn thing still stripped... like before i used the hex key i soaked the thing in WD40 for like 30 min, thats y there are wet marks in the picture hehe. but durn!!! this just ticks me off... but yeah 10-15 from honda or acura... should i just buy some of grey's endlinks u think???
as for the vice grips, me and my friend tried it, and it still wont budge... now the prob is how to get the enlink off... its hard to reach the lover part of it to take it off the frame, even with the wheel off.
Old Mar 6, 2007
TRIZ's Avatar
Saw it off. Or throw the wheel on, and drive out to a shop and let them deal with the problem.
Old Mar 6, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
just get grey's endlinks
Old Mar 15, 2007
LT2004ever's Avatar
wouldn't the stock endlinks still work fine, if i just ran out to honda?
Old Mar 15, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
it might hold for a while...stock endlinks are fine for stock sway bar...lot of people break their endlinks with upgraded sway bar...
Old Mar 15, 2007
bobsagator's Avatar
Stop the rumor! The RSX bar is a stock bar so why wouldn't stock endlinks work? RSX and Civic endlinks are the same. The only rear sway that has more of a tendency to break stock endlinks is the Progress bar. Any endlink can break, and it is usually dependant on the driving, but the stock endlinks work just fine.
Old Mar 15, 2007
LT2004ever's Avatar
Whoot! thanx for that info.
Old Mar 15, 2007
susuking's Avatar
susuking is on a distinguished road
take it to the shop. and stop making it worse, or just cut it off and get a new one replace
Old Mar 15, 2007
robbclark1's Avatar
Retired suspension supermod.
Tried to give you rep but it won't let me.
1) It is a stock bar, so it probably won't break. The only sway bar that has been shown to break stock endlinks is the progress 22mm because of it's odd shop. The 24mm progress bar comes with endlinks.
2) Saw the endlink off and get a new one. That's all you can do.
Old Mar 15, 2007
LT2004ever's Avatar
Like im not making anyworse, cause im not messin with it anymore lol, at least untill i buy new endlinks
arg! sawing and my civic! it sound so painful
Old Mar 16, 2007
metalviper's Avatar
just opt for the upgrade! its ur best bet unless u cant come up with the money then get stock replacements off ebay or somethin.
Old Mar 16, 2007
DriftR's Avatar
DriftR is an unknown quantity at this point
Next time, you shoud use the hex key only to lock the spindle in place to keep it from rotating and apply torque to the nut instead.
Old Mar 16, 2007
LT2004ever's Avatar
thats what i did, but it still stripped it..... i guess i just need something better than wd40 lol
Old Mar 17, 2007
robbclark1's Avatar
yah...a hacksaw!
Old Mar 29, 2007
LT2004ever's Avatar
Re: Ran into a problem
stupid rain is preventing me from getting out there and under my car again!
Old Mar 29, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
i would of thought the vice grip would work 4 sure, thats what we use when the hex on the shocks/strut cover gets stripped and it works all the time...end links im not to sure about...good luck
roverben
Jan 21, 2019 05:16 PM
usajags84
May 30, 2015 06:49 PM
DouglasTheGreat
May 27, 2015 11:23 PM
dragonsblood
Apr 27, 2015 12:28 PM
civic_gt
Apr 19, 2015 08:15 AM
