about to change head gasket and timing belt. UPDATE! 2/22/07
ok i got the valve cover off and all that jazz... i read somewhere that you can replace the headgasket without removing the timing belt? the timing belt removal looks like a PITA. it also says you need to buy a special tool to hold the crank pulley in place which is 60 bucks. i dont know if autozone has the rent-a-tool for this. anyways yeah. how do i take the head off without taking the timing belt off? i was also looking to put in new arp head studs just because the head is coming off.
you need to pull the crank pulley anyway to get to the tensionor for the timing belt. if the head is coming off, i would replace the headgasket, timing belt, water pump, timing belt tensionor, cam seal, valve cover gasket, and im sure theres another thing or 2. head bolts should also be replaced but youre going with arp studs so youll be ok there. as for the tool, you can do it without the tool if you have an impact gun. if you dont have an impact gun or the funds to buy the tool and you have a manual trans, put the ebrake on as hard as you can, put the trans in 1st, put a huge breaker bar on the crank pulley bolt, and twist that bitch off.
the whole engine still moves even when my car is in gear. thats not normal is it? lol.
will this tool work? eBay Motors: Honda/Acura Crank Pulley Removal Tool 50mm (item 160088074008 end time Feb-27-07 21:10:31 PST)
i cant find that pulley holding tool anywhere.
the bolt for the crank pulley is standard thread. lefty loosey righty tighty. yes that took will work. did you have your front tires off the ground when you were trying to take it off? probably so. you need a flex head breaker bar and do it from under the car with the tires on the ground.
a regular socket wrench with a breaker bar wouldnt work? and there is no way i can fit under my car its too low. ahah. thanks for all your help unclejuice. on my crankshaft pulley i do not see the UP engraving on there. i guess il have to mark all the pulleys and the block and the camshaft so i dont screw up the timing.
the crank wont have "up" marked on it. thats the cam gear. the crank pulley has 4 lines on it right next to where the belt goes. 3 close together and one by itself to the right. the red line in the middle is your tdc mark that needs to be lined up with the pointer on the block.
^^ thanks. im all done. i jsut changed the headgasket no studs. had no money for that. i think i will do that within the month i couldnt afford so much down time. that you everyone tht helped i couldnt have done it without you
especially unclejuice...
especially unclejuice... Thread
hokiedad4
May 3, 2015 10:06 PM
deus-ex
Apr 13, 2015 12:29 PM
