Header problem Help please....
Old Feb 14, 2007
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Hey y'all... Well I went out and bought a polished header, and so far after a lot of elbow grease and liquid wrench, I was able to remove the top 5 nuts/bolts holding the header onto the block, but I can't remove the bolts connecting the header to the downpipe. In looking at the bottom of the header, it almost looks like the nuts are welded onto the OEM header. Is this correct? Also how can I remove the last two bolts. Anyone that has replaced their header please help me out. Spent about three hours 2 nights ago just trying to remove those last two bolts. I'm gonna try my friend's air rachet, but I don't want to strip the head off the bolts. Please please help me out... Thanks.
Oh yeah, any pix would greatly be appreciated.
Old Feb 14, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
The nuts are suppose to be welded on. You are trying to loosen the bolts not the nuts right?
Old Feb 14, 2007
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
They are welded to the header. You have to take the bolts out from underneath. They are spring loaded. Using a air wrench will not help U any. Sorry I have no pics for ya. But if U look at the header where its meets the downpipe U will notice 2 spring loaded bolts U will have to take them out from underneath. All U need is an extension and a 10mm socket I believe but I may be wrong. Once U get those 2 bolts out the header will come right off.
Old Feb 14, 2007
Yeah, I was working on the bolts underneath, but they wouldn't turn. I went out and bought another extension yesterday, so I'll give that a try. Now you said they were spring loaded, is there anything that needs to be done to loosen the bolt prior to taking a socket to it?
Old Feb 14, 2007
Nope just keep turning.
Old Feb 14, 2007
affixrider's Avatar
affixrider will become famous soon enough
righty tighty lefty losey
Old Feb 14, 2007
^^^ Yeah thanks... lol... Ok... I'll continue trying and kill a few more brain cells inhaling that stupid liquid wrench. Is there a better product out there to get at stubborn bolts???
Old Feb 14, 2007
Valdeezy's Avatar
They are stubborn but U just have to work at it.
Old Feb 14, 2007
Da1lyDr1ver's Avatar
PB Blaster works wonders on stubborn bolts, but i dont think it will help you anymore in your case.
Old Feb 14, 2007
I would use an impact wrench if you can get one, that's what I used. You could also try heating them up if you have a torch.
Old Feb 14, 2007
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Mister frankies right on. Impact wrench is what you need, if you cant get that heat them up with a torch.
Old Feb 14, 2007
TRIZ's Avatar
For old rusty bolts and nuts, def bust out a torch and get them heated up real nice, but make sure u dont torch any of the other stuff in your engine bay like the O2 seonsors and stuff! From what I remember, the part on the top is welded on, so stay down and keep hitting them from the bottom.
Old Feb 14, 2007
Like Arnold S. used to say, GET DOWNNN!
Old Feb 16, 2007
Thanks for all y'alls input. I finally got it off using a breaker bar, gator grip, and a **** load of liquid wrench...
Old Feb 16, 2007
^^^ thats good.
i personally wouldnt recommend using an impact gun on stuck bolts. theres a very high chance you will strip the nut or bolt doing it this way. at least with hand tools, you can "feel" what you are doing.
Old Feb 16, 2007
In my personal experiences I've stripped more bolts with hand tools but that's just me.
Old Feb 16, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
well, for me... Torque Wrench is man's best fwen!! no electric power Ftw!
Old Feb 16, 2007
pon55's Avatar
^ ^ ^ thats me too!
The air impact wrench works great! (out, not in)
EK_Eddy
Jun 6, 2015 07:31 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
SOHCScreamer
Dec 21, 2001 10:10 PM
AEMcivic
Dec 5, 2001 04:02 PM
DC5@EM2
Dec 4, 2001 07:53 PM
