How to replace a front rotor
Old Jan 11, 2007
gbwells's Avatar
gbwells is an unknown quantity at this point
I need instructions on how to replace a front rotor on my 2000 Civic SI. I really need help.
Old Jan 11, 2007
TRIZ's Avatar
cummon buddy- after you yank the wheel off your half way there.
1) park on a level surface, put block behind rear wheels, loosen front lugnuts on the wheel your doing work on, jack up the front of the car, slide the jack stands under it.
2) Remove the loosened lugnuts and slide the tire off. Give it a good inspection
3) follow this diagram in figuring out how it connected.
That should do it for ya
Old Jan 11, 2007
lxcivic2k1's Avatar
The rotor wont' just fall off though, your gonna need to hit it a little with a hammer on the back to get it to come off.
Old Jan 15, 2007
DDragon7's Avatar
Hardest part is getting the screw off if its rusted.
Old Jan 15, 2007
Nyte's Avatar
Nyte will become famous soon enoughNyte will become famous soon enough
Yeahh, if the screw is rusted good luck. I went to honda and bought new screws, then i drilled out the old one cuz i had no luck getting it out. after i drilled it out i tapped the side with a mallet and the rotors popped out. but no matter what i think you should buy extra screws cuz i'm guessing you may strip the old ones or something. I thought getting the screws off was the hardest part.
Old Jan 15, 2007
HyeHonda05's Avatar
Official Wish He Knew It All
My mechanic told me you dont need the screw actually. He was saying that they are there only to hold the rotor in place while the car is on the assmbely line and that it does not do anything really after that since the wheel holds the rotor on.
Old Jan 15, 2007
Nyte's Avatar
Well yeah cuz it just holds the rotor enough for it to stay on, but..you should just get new screws anyways. they're like $.10cents at honda for each.. So its no harm getting new ones.
Old Jan 15, 2007
robbclark1's Avatar
Retired suspension supermod.
You don't need the screws. I have been running fine without them since the first time I changed my rotors. Most European cars don't even come with them.
the harm in getting new ones is that they are cheap metal that warps easily and makes it difficult for you to change your rotors.
Old Jan 15, 2007
blouisgod's Avatar
Life Begins > 6800rpms
Yeah, the screws are worthless in a floating rotor. Just drill the old ones out and dont bother replacing them; they are more for the factorys use on the line.
Old Jan 15, 2007
sl33pyriceboi's Avatar
to take those scres off go to sears or something and get an impact screwdriver.......it works wondners......worth the 20 bucks
Old Jan 15, 2007
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
ya the correct tool to take the rotors off is a impact screw driver, not some hand power device
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
bsmiley
Apr 27, 2015 01:27 PM
chgofirefighter
Apr 18, 2015 08:08 PM
tattedlariat
Apr 12, 2015 07:55 PM
thesushiboy
Apr 12, 2015 02:54 AM
