Backseat
Old Dec 12, 2006
Keyees's Avatar
Keyees is an unknown quantity at this point
Backseat
Hey guys I looked all over for a DIY on how to remove the backseat in a Coupe. I have a 2001, I just need to get the backseat out so I can get a piece of plywood behind the fabric so I can mount an AMP to it. And I was told that the only way to unzipper it was to remove it.
Old Dec 12, 2006
04NiGhTHWK's Avatar
04NiGhTHWK has a little shameless behaviour in the past
Look in ur honda manuel. Should be in there. look under the trunk section.
Old Dec 12, 2006
Rufus's Avatar
Actually on the bottom of the back there is a piece you can remove and prolly slide the wood up without even removing the seat.
Old Dec 12, 2006
04NiGhTHWK's Avatar
U know you can fold the seat down and then remove it that way right.
Old Dec 13, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Included with the rear deck removal DIY. Located HERE.
Old Dec 13, 2006
Keyees's Avatar
Thanks for the help guys, my AMP just got delievered to my house a couple hours ago and Im dieing to get started. But I will have to wait untill the weekened. Thanks guys!
Old Dec 14, 2006
Keyees's Avatar
I took a look behind the fabric today and found out Im gunna have to drill the holes right into the metal. Anything I should know before I do this? I dont wanna kill myself. Ive got a cordless drill and lots of drill bits but are there special drill bits for metal?
Old Dec 14, 2006
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
ya... deff. get a metal drill bit.. you can pick one up at home depot for like 2 bucks... if not ull just break bits....
Old Apr 28, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Backseat
I know it's late, but this is for anyone who finds this thread on a search like I just did. You can get wood behind there without removing the seat, I did it on both sides. Fold down your rear seats and unhook the fabric from itself on the bottom part of the rear. Then unzip both sides and voila. Insert wood, zipper up again. You probably won't be able to get the fabric hooked back together but who cares.
Old May 2, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
Re: Backseat
^^^^ exactly their is no need in removing the backseat. just follow dex's advice, so much easier. make the wood a little smaller though so that the fabric can zip back up.
Ezql
May 26, 2015 11:46 PM
ADS
Jul 18, 2005 08:52 AM
pnoyster2k1cvic
May 24, 2004 01:26 AM
six_storm
Jan 14, 2004 02:36 PM
hyperactive
Jun 25, 2002 02:31 PM
