Removing the Backseat
Old Jul 18, 2005
ADS's Avatar
ADS
ADS is an unknown quantity at this point
Alright i have a 2003 coupe and well after installing my sparco sprints which dont recline i have found very little use for the backseat has anyone taken/ripped theres out if so how long/ how hard/ how many F**k up's and if u have any instructions it would be greatly appreciated
Old Jul 18, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
Its not to hard to take off the backseats, basically the bottom pop's out, and the tops, are secured on the side *where it swings aka the hing* you just unbolt it, and bada bing bada boom, the seats are out.
Old Jul 18, 2005
jb1004's Avatar
jb1004 will become famous soon enoughjb1004 will become famous soon enough
Yeah it's really easy. There are only like 6 bolts that hold everything in. Just search for the diy.
Old Jul 18, 2005
ADS's Avatar
ADS
Thanx For the help anyone done this removal and could u post up some pics of how it turned out I am planning on turning my subs, amps to face foward through the back seat opening and then finishing the floor in plywood and carpet or somethign along those lines.
Old Jul 18, 2005
ADS's Avatar
ADS
Plus is it possible to remove the stock seat belt attachements to completely remove the seat belts from the car?
Old Jul 18, 2005
ADS's Avatar
ADS
Again guyz thanx s for the help
Old Jul 18, 2005
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
It is REALLY easy to remove them. It would take you like 10 minutes (if that). Pull up on the front of the bottom part, there are 2 clips on the front. If you reach down into the middle of the seat (where the top and bottom meet) there is a single 10mm bolt holding the bottom on. Fold down the tops and on the left seat, there is a velcroed peice of fabric on the right side of it, pull it up and there are two 10mm bolts. Take those out and you can then maneuver the tops out. I'm sure the seatbelts can just be unbolted.
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
