Viper 5000 + Remote Start
Old Dec 9, 2006
vteck2005's Avatar
vteck2005 is an unknown quantity at this point
Hey,
This summer i had installed a Viper 5000 alarm system in my car, and i didn't get the version with the remote start. I really don't know my reasoning, as to why i didn't get it, so don't ask, lol.
Now that its winter, i regret it.
So i was wondering if i could get just install an attachment to the system, that would still show whats going on on my LCD remote.
I asked Futureshop, but they told me i have to remove my entire alarm system and install a new one, which is bullshit, because DEI sells a remote start addition.
So my question is, can i get it be done by someone else, without ruining the warranty with Futureshop, and is it somewhere in the GTA?
Thanks,
Old Dec 9, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
If you get something like an Avital 4000 and use an output from the viper alarm to trigger the white/blue activation input you'll be fine. I'm not too familiar with the 5000 but if it's LCD most likely you'll get confirmation it receives your AUX signal so that would be your confirm on remote start.
Old Dec 9, 2006
vteck2005's Avatar
Will that still show up on my remote as engine on,
Will the doors still stay locked and shocksensor disabled?
Thanks,
Old Dec 9, 2006
It won't show up specifically as having the engine on but it will give you confirmation it received the auxiliary signal implying the engine is on (so long as the avital 4k or whatever starter unit is properly installed). Doors will stay locked as long as ignition controlled lock/unlock is programmed off. The ignition output or another output of the avital (blue status out also) can be used with a relay to break the power to the shock sensor while it's on.
You can do it for sure, it's all about the install. If you want specifics like exact wiring just ask. I do this kind of stuff all day long.
Old Dec 9, 2006
vteck2005's Avatar
Yeah, an exact wiring would be helpful,
Thank you very much.
Old Dec 9, 2006
I'll bang it out for you tomorrow at work and post it some time during the day.
Old Dec 9, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
holy crap at noob-wit-knowledge.. good to have this guy around for electrical needs.. rep to you for not being a dick.
Old Dec 10, 2006
Haha, lol. Thanks man, I appreciate it. When it comes to suspensions, engines, etc. I'm still learning. On the electrical stuff though, especially related to aftermarket, I've seen and done just about all of it and if I haven't done it I've heard about it.
Back to the project at hand. We'll say for simplicity sake we're using the Avital 4000 (4k) as the addon starter and the viper 5000 (5k) will trigger it.
Triggering 4k with 5k
5k: white/blue (-) ch3 on main harness is the output.
4k: white/blue (-) activation input is what gets hooked up to white/blue from the 5k. The programming on the 4k needs to be changed, option 8 is set at default of 2 pulses and needs to be changed to 1.
To remote start the car: press the lock and unlock buttons at the same time for about a second on the 5k remote. The 3 symbol should light up on the 5k remote signaling it transmitted and received the auxiliary. This is your confirmation for remote start.
Using status output from 4k to disable shock sensor during start
The blue (-) or blue/white (-) status output from the 4k needs to be hooked up to the 5k to disable shock sensor. A diode needs to be placed between the two units with the stripe facing the 4k. The other side of the diode will be hooked up to the blue wire on the main harness of the 5k (H1/7).
I've never used a viper 5000 this way and its kind of interesting because the manual says it will transmit a remote start on notification to the HHU?. I'm not sure if this means you will get a normal confirmation (a little exhaust trail) on the remote or if you'll just have the channel 3 confirm but either way you'll have something. The only other trick is make sure ignition lock/unlock are programmed off on the 5k unit. I think that's about it. Any other questions, let me know.
Old Dec 11, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
rep'd u for the clifford help.
Old Dec 11, 2006
Thanks man, I hope you got everything working.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
DaveyD
Mar 28, 2003 12:28 AM
Trey
Jan 6, 2002 02:30 AM
loquito
Nov 12, 2001 07:24 PM
