what does this plug do? (vtec head)
Old Nov 26, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
theres a little white plug under the solenoid. anyone know what it is and if ill have to hook it up to something when i do my head swap?
Old Nov 26, 2006
anyone???
Old Nov 26, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I don't know, I didn't hook it up, my car ran fine.
Old Nov 26, 2006
works for me. now i just need the ecu pinout for 04-05
Old Nov 27, 2006
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
thats the oil presure switch. it's so the ecu knows u have adiquit oil pressure for vtec to engage with. not sure if it will cause DTCs on out cars or not.
Old Nov 27, 2006
i saw it in the honda service manul today. im not going to hook it up if i can ever get my vafc-ii working so i can use the head.
Old Nov 27, 2006
XSRCivic's Avatar
d17a1 wire harnesses dont have this plug of course since it doesnt have vtec. Many people have run this swap without using that so you should be fine.
Old Nov 28, 2006
Buds302's Avatar
Buds302 will become famous soon enough
yea thats what that is. the oil pressure sensor. once again since your car didnt have Vtec then you dont need to worry bout it. but i do believe if you use a OEM Vtec ECU then you have to wire up that plug. it lets the ECU know that theres enough oil pressure to engage Vtec. if using a Vtec controller then this plug is not needed. by Vtec controller i mean your VAFC II that you say you have
Old Nov 28, 2006
yeah ive got a vafc-ii if i can ever get it working. its all wired up but it wont come on when the switch is on.
Old Nov 29, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Just looked in the manual at it, its just the pressure switch for VTEC fluid as was previously stated, and looks like it can just be ignored. The test for jumping the solenoid itself is completely independent from the pressure switch, so bypass it/ignore it. Keep in mind that that switch is there for a reason, and be mindful of your oil pressure even though the computer isn't checking for you. IIRC if the engine is too cold, it won't engage, and without the switch, it will.... thick oil, little hole, probably not a good idea. Either use RPMs to engage it, or you can use e-manage and the greddy MAP sensor to control it with the map sensor voltage.
Old Nov 29, 2006
drunkenmagnum's Avatar
when i replaced my headgasket i ran the wrong wire to this and ****ed it up. if your oil light comes on do not drive it anywhere, that part is like $120.
Old Nov 30, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
i think this was in another thread i gotta search for it
Old Nov 30, 2006
well ive got backup parts now. just picked up a full d17a2 complete with starter and everything. bought the whole motor just for the rods since i bent mine when i hydrolocked the motor.
thana
Jun 15, 2020 07:05 PM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
MiniMi
May 27, 2015 01:57 PM
Dakker
Jan 21, 2002 12:55 PM
