Wiring and circuits help plz!
Old Mar 18, 2002
triz08's Avatar
triz08 is an unknown quantity at this point
hey
I have like 4 neon lights, washer lights, glow wirez, and strobes. I want to hook them up all on seperate switches but i know one circuit cant hold all the power running through it. How do i make them not over flow with power and pop fuses. Can i someone make my on circuit for this??? thx
~Mike
Old Mar 18, 2002
Drew's Avatar
Drew is an unknown quantity at this point
dont know the anwser to ur question, but next times, post them in the tech stuff forum, not the general ramblings forum and u might just get some more responses.
-drew
Old Mar 18, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
One thing you can consider is makeing a whole new circuit of the battery using like ten or twelve gauge power wire, kind of like wiring up an amplifier. Then use a larger fuse in the inline fuse holder. You will just figure out how many amps the entire thing will draw, then use that as a base for how large of a fuse would be. Hold on...I will post you a picture of what I mean. I have quite a few extra goodies running in my car, so I made it's own little circuit.
Old Mar 18, 2002
VTECnique's Avatar
VTECnique is an unknown quantity at this point
i was gonna try the Arospeed red grounding cables to do that (except i would hook it up to the positive battery terminal instead). Should work i think... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 18, 2002
APS's Avatar
APS
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG]Here you go. I hope this helps clarify things up some.
Old Mar 18, 2002
APS's Avatar
APS
oops....
Old Mar 18, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Keep in mind that you need to check that Amperage rating of your switch as well. Most switched (especially smal toggle switched) are not designed for any significant current draw. I would recommend using the switch to supply the ground of a relay.
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
sch2cm
Jul 21, 2015 09:58 PM
jody501
Jul 10, 2015 11:01 AM
robbie374
Jul 7, 2015 02:56 AM
