Crank Pully????
Old Oct 24, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
Question Crank Pully????
sorry ita a long question, i am taking the head off... i need a chain wrench to pull of the crank pully so the timing belt lower plastic cover can come off so i can get to the timing belt tensioner, now i need the chain wrench to unbolt the nut of the crank pully, i cant find the chain wrench anywhere, i looked in napa, autozone, advanced, homedepot.... i cant find it. does anyone know if i can take off that crank pully without the chain wrench? a way to hold the crank pully while i am unbolting the nut without spinning the crank?
dalibor
Old Oct 24, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Someone had a link here, did you search crank pulley?
Old Oct 24, 2006
Logan3024's Avatar
http://www.etoolcart.com/index.asp?P...OD&ProdID=7869
Old Oct 24, 2006
BoostedVik's Avatar
thats not what i am looking for... thanks for trying i can get to the nut but i cant unbolt it without spinning the WHOLE crank.
Old Oct 24, 2006
I <3 1000grid's Avatar
I <3 1000grid is an unknown quantity at this point
Everyone to the darkside! www.importpassion.com PS use SLO REX as a referral name
Old Oct 24, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
ususally am impact gun takes it off for me... soak the bolt in wd40 for a few minutes and impact it off... of all the many times i had to pull those things off i have never used such a tool... not once
Old Oct 24, 2006
woot let the revolution begin! Bannage?
Old Oct 25, 2006
BoostedVik's Avatar
well i dont have a shop with all the tools in my back yard... i have a honda civic service manual and they are suggesting on using the chain wrench to hold the pully while unbolting the nut, i am not having hard time removing the bolt but holding the crank pully in one place... i also searched but the only thing i got its, crank pully special tool which can be rented but those will not due on a honda pully cuz i doesnt have any holes or gaps in the pully, its solid. thanks for your help guys!
Old Oct 25, 2006
streetglower's Avatar
the honda service manaul doesnt recommend a chain wrench, and what you need is what was posted above, the honda crankshaft tool. it fits in the middle of the crank to hold it in place and you put your wrench on the bolt to loosen the nut.
When I did my timing belt, I just had a shop loosen the nut for me. was charged $20 to loosen it and then when I was done I brought it back and they tightened it for me. the bolt was too damn tight for me to break loose.
Old Oct 25, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I just simply built one
Old Oct 25, 2006
D17master081's Avatar
D17master081 is an unknown quantity at this point
i heard if you put the car in 5th gear n have someone hold the brake down....that will stop the crank from turning while ur trying to loosen the nut....thats just what i heard n i could b wrong
Old Oct 25, 2006
BoostedVik's Avatar
i wish i can take it to the shop my head is almost ready to come off all i need to do is get the timing belt off the cam and take out the head studs and its out. i guess i will try the renal tool, whats the worst that can happen i can always return it
Old Oct 26, 2006
BoostedVik's Avatar
my friend is actually going to fabricate me a honda crank pully holder by friday so everything is on hold till then
Old Oct 27, 2006
they do sell electric powered impact guns that dont require an air compressor.. something you might want to think about investing it.. i have one myself
Old Oct 27, 2006
that isnt going to bust loose the crank bolt.
Old Oct 27, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
if you got it on an engine stand, could have a friend hold a screwdriver in between the flywheel tooth and the bolt on the stand while you loosen the bolt, had to do that while rebuilding a 2.2 in school. instructor swears by that method, cheap and usefull
Old Oct 27, 2006
i have used it on all the cars that we work on at the shop.. dont see why it shouldnt otherwise??? everyones entitled to there own opinion.. lol.. anyways.. it works for me
Old Oct 27, 2006
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
USE AN IMPACT GUN WITH A LOT OF PSI! Works like a charm my friend
Old Oct 28, 2006
BoostedVik's Avatar
i dont have an impact gun with a lot of psi.... i will show you guys what my friends grandfather fabricated for us... but the tool looks good! i will take a picture and post it.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
